Question about Janome Memory Craft 9000 Computerized Sewing Machine
Shut down in the middle of sewing and will not turn back on.
I was in the middle of sewing through some fairly thick material on my Jenome 9000 and the machine cut off. The machine will not come back on no matter what I do. Any suggestions?
  • 51 Answers
Was it tired? The bobbin case is locked in place, because of tread or lint.
The "hook" will not move. Take the bobbin unit apart and clean and oil the hook (yes, oil, just a Q-tip amount).
Keep on Sewing
Posted on Sep 06, 2009
I sew thin leather w/Janome MC4000 using leather needle. Want to try thicker leather but not damage machine. How thick will this machine take?
Be careful sewing thick materials with a domestic machine. Even though a lot of machines are supposedly able to sew thick leather & fabrics, it could damage your machine in the long run. If you value your machine, you might want to find a second machine (used mechanicals, older Singers, etc., probably work better for this purpose) to sew thick fabric. Save your nice primary machine for more conventional uses.
Dec 13, 2015 | Sewing Machines
Where is the control for different material thicknesses
test sew on the different material to see if the thread tension has to be altered with the different thickness thread
Nov 29, 2015 | Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
I need to know how to change the pressure between the foot and the sewing plate. I have no problem doing regular sewing but when I try to do several layers (such as quilting) the pressure is too much and...
The rotary control on the left-hand end of the sewing arm controls the foot pressure. You shouldn't normally need to vary this, except when quilting thick materials. The control is normally set with the 'bar' in the middle of the knob straight up-and-down, but you can reduce the pressure by turning it - the markings on the head cover correspond to increasing and decreasing the foot pressure.
Aug 04, 2011 | Bernina Artista 170
What is the best kind of sewing machine to buy for someone who sews?
i would suggest a good machine that is around 300 dollars is the Kenmore Model number 19110, my wife just bought one and loves it. its made by Jenome.
Mar 11, 2011 | Janome Memory Craft 9000 Computerized...
Problems when sewing over heavy jean hems
Are you using the correct type of needle? have a word with your needle supplier and explain the problem. Different threads and different thickness material need different top and bottom tension adjustments.
Can I suggest sew one thickness material at a time with tension adjustments for that thickness. Then change the tensions and do a batch of thicker material.
Mar 29, 2008 | Juki DDL-8700
Janome Memory Craft 9000 Computerized Sewing Machine Logo
100 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
