What mechanics ? No codes stored in driver door module or power seat module ? Or don't these mechanics know about that ?
Did you try the dealer ?
Diagnostic Trouble Code (DTC) Chart
DTC
Description
Source
Action
B1201
Fuel Sender Circuit Failure
HEC Module
REFER to Section 413-01 .
B1204
Fuel Sender Circuit Short to Ground
HEC Module
B1205
Failure (Open or Short to Battery)
HEC Module
REFER to Section 413-08 .
B1208
HEC Switch-1 Assembly Circuit Short to Ground
HEC Module
B1213
PATS Number of Programmed Keys is Below Minimum
HEC Module
REFER to Section 419-01 .
B1231
Longitudinal Acceleration Threshold Exceeded
RCM
REFER to Section 501-20B .
B1232
PATS Bad Diagnostic Byte Received
HEC Module
B1249
Blend Door Failure
EATC Module
REFER to Section 412-00 .
B1251
Climate Control Air Temperature Internal Sensor Circuit Open
EATC Module
B1253
Climate Control Air Temperature Internal Sensor Circuit Short to Ground
EATC Module
B1255
Climate Control Air Temperature External Sensor Circuit Short to Battery
EATC Module
B1257
Climate Control Air Temperature External Sensor Circuit Short to Ground
EATC Module
B1261
Climate Control Solar Radiation Sensor Circuit Short to Ground
EATC Module
B1312
Headlamp Input Circuit Short to Battery
LCM
REFER to Section 417-01 .
B1317
Battery Voltage High
HEC Module
REFER to Section 414-00 .
B1317
RCM
B1317
Air Suspension Module
REFER to Section 204-05 .
B1318
Battery Voltage Low
HEC Module
B1318
Low Ignition Voltage During Speed Control Operation
NGSC Module
REFER to Section 310-03 .
B1318
Battery Voltage Low
B1318
Battery Voltage Low
RCM
B1322
Door Ajar LF Short to Ground
DDM
REFER to Section 501-14B .
B1334
Decklid Ajar Rear Door Circuit Short to Ground
LCM
B1340
Chime Input Request Circuit Short to Ground
LCM
B1342
ECU is Defective
ABS Module
CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new ABS Module. REFER to Section 206-09 . CLEAR the DTCs. REPEAT the self-test.
B1342
ECU is Defective
ACM
CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new ACM. REFER to Section 415-01 . CLEAR the DTCs. REPEAT the self-test.
B1342
ECU is Defective
CPM
CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new CPM. REFER to Section 419-08 . CLEAR the DTCs. REPEAT the self-test.
B1342
ECU is Defective
DDM
CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new DDM. REFER to Section 419-10 . CLEAR the DTCs. REPEAT the self-test.
B1342
ECU is Defective
DSM
CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new DSM. REFER to Section 419-10 . CLEAR the DTCs. REPEAT the self-test.
B1342
ECU is Defective
HEC Module
CLEAR and DOCUMENT the DTCs. PERFORM the HEC self-test. If DTC B1342 is retrieved, INSTALL a new HEC Module. REFER to Section 413-01 . CLEAR the DTCs. REPEAT the self-test.
B1342
ECU is Defective
LCM
CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new LCM. REFER to Module-Lighting Control (LCM) in this section. CLEAR the DTCs. REPEAT the self-test.
B1342
ECU is Defective
NGSC Module
CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new NGSC Module. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test.
B1342
ECU is Defective
CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new air suspension module. REFER to Module-Air Suspension in this section. CLEAR the DTCs. REPEAT the self-test.
B1342
ECU is Defective
RCM
B1352
Ignition Key-In Circuit Failure
LCM
REFER to Section 413-09 .
B1359
Ignition RUN/ACCY Circuit Failure
LCM
REFER to Section 211-05 .
B1396
Power Door Lock Circuit Short to Battery
DDM
B1397
Power Door Unlock Circuit Short to Battery
DDM
B1402
Driver Power Window Down Circuit Failure
DDM
REFER to Section 501-11 .
B1445
Door Handle Circuit Short to Ground
DDM
B1446
Wiper PARK Sense Circuit Failure
LCM
REFER to Section 501-16 .
B1484
Brake Pedal Input Open Circuit
ABS Module
B1485
Brake Pedal Input Circuit Short to Battery
LCM
B1526
Keyless Entry Circuit Short to Ground
DDM
B1529
Memory Set Switch Circuit Short to Battery
DDM
REFER to Section 501-09 .
B1533
Memory Position No. 1 Switch Circuit Short to Battery
DDM
B1537
Memory Position No. 2 Switch Circuit Short to Battery
DDM
B1545
Seat Direction Switch Assembly Circuit Short to Battery
DDM
REFER to Section 501-10 .
B1549
Power Window Master Circuit Short to Battery
DDM
B1553
Decklid Release Circuit Short To Battery
DDM
B1555
RUN/START Input Circuit Failure
LCM
B1556
RF, LR, RR Door Ajar Circuits Short to Ground
DDM
B1569
Headlamp High Beam Circuit Short to Battery
LCM
B1577
Parking Lamp Input Short to Battery
LCM
B1581
Panel Dim Increase Input Circuit Short to Battery
LCM
REFER to Section 413-00 .
B1585
Panel Dim Decrease Input Circuit Short to Ground
LCM
B1600
PATS Key Problem - No Key Code
HEC Module
B1601
PATS Received Non-Programmed Key Code
HEC Module
B1602
PATS Received Invalid Key Code Format
HEC Module
B1663
Driver Seat Front Up/Down Motor Stalled
DSM
B1664
Driver Seat Rear Up/Down Motor Stalled
DSM
B1665
Driver Seat Forward Backward Motor Stalled
DSM
B1666
Driver Seat Fwd/Bwd Recline Motor Stalled
DSM
Also do there know anything about serial data bus ?
Plus , do they know what voltage drop testing a electrical circuit is . I should find better mechanics .
There are two things possible. 1) You have defective re chargeable batteries in your GoGear. 2) There is some short circuit because of which the re chargeable cells are discharging. Either way you should get the system changed. If you want to confirm if its the battery defect or GoGear. Charge the system fully and play music continuously. If the Go Gear plays for about 4 hours with out break---- its not the battery but the charging system.
It could be , but to replace it without testing would not be a wise idea . These modules can set DTC'S - diagnostic trouble code's .Having a qualified repair shop check it would be your best bet .
It's called driver seat module . DSM Diagnostic Trouble Code (DTC) Index
DTC
Description
Source
Action
B1342
ECU Is Faulted
DSM
B1530
Memory Set Switch Circuit Short to Ground
DSM
Go To Pinpoint Test J .
B1534
Memory 1 Switch Circuit Short to Ground
DSM
B1538
Memory 2 Switch Circuit Short to Ground
DSM
B1663
Seat Driver Front Up/Down Motor Stalled
DSM
If the motor does not operate, Go To Pinpoint Test H (Navigator) or Go To Pinpoint Test I (Expedition). If motor operates, Go To Pinpoint Test J .
B1664
Seat Driver Rear Up/Down Motor Stalled
DSM
B1665
Seat Driver Forward/Backward Motor Stalled
DSM
B1666
Seat Recline Forward/Rearward Motor Stalled
DSM
If the motor does not operate, Go To Pinpoint Test H (Navigator). If motor operates, Go To Pinpoint Test J .
B1667
Mirror Driver Up/Down Motor Stalled
DSM
B1668
Mirror Driver Right/Left Motor Stalled
DSM
B1669
Mirror Passenger Up/Down Motor Stalled
DSM
B1670
Mirror Passenger Right/Left Motor Stalled
DSM
B1676
Battery Voltage Out of Range
DSM
B1703
Seat Driver Recline Forward Switch Circuit Short to Battery
DSM
B1707
Seat Driver Recline Rearward Switch Circuit Short to Battery
DSM
B1711
Seat Driver Front Up Switch Circuit Short to Battery
DSM
B1715
Seat Driver Front Down Switch Circuit Short to Battery
DSM
B1719
Seat Driver Forward Switch Circuit Short to Battery
DSM
B1723
Seat Driver Rearward Switch Circuit Short to Battery
DSM
B1727
Seat Driver Rear Up Switch Circuit Short to Battery
DSM
B1731
Seat Driver Rear Down Switch Circuit Short to Battery
DSM
B1735
Mirror Driver Vertical Switch Circuit Short to Battery
DSM
B1739
Mirror Driver Horizontal Switch Circuit Short to Battery
DSM
B1743
Mirror Passenger Vertical Switch Circuit Short to Battery
DSM
B1747
Mirror Passenger Horizontal Switch Circuit Short to Battery
DSM
B1950
Seat Rear Up/Down Feedback Potentiometer Circuit Failure
DSM
B1952
Seat Rear Up/Down Feedback Potentiometer Circuit Short to Battery
DSM
B1954
Seat Front Up/Down Feedback Potentiometer Circuit Failure
DSM
B1956
Seat Front Up/Down Feedback Potentiometer Circuit Short to Battery
DSM
B1958
Seat Recline Fwd/Backward Feedback Potentiometer Circuit Failure
DSM
B1961
Seat Recline Fwd/Backward Feedback Potentiometer Circuit Short to Ground
DSM
B1962
Seat Horizontal Forward/Rearward Feedback Potentiometer Circuit Failure
DSM
B1964
Seat Horizontal Forward/Rearward Feedback Potentiometer Circuit Short to Battery
DSM
B1987
Pedal Forward / Rearward Motor Stalled
DSM
REFER to Section 206-00 .
B1988
Pedal Position Forward Switch Circuit Short to Battery
DSM
B1989
Pedal Position Rearward Switch Circuit Short to Battery
DSM
B1990
Pedal Forward/Rearward Feedback Potentiometer Circuit Failure
DSM
B1991
Pedal Forward/Rearward Feedback Potentiometer Circuit Short to Battery
DSM
B2312
Mirror Passenger Horizontal Feedback Potentiometer Circuit Failure
DSM
B2314
Mirror Passenger Horizontal Feedback Potentiometer Short to Battery
DSM
B2316
Mirror Passenger Vertical Feedback Potentiometer Circuit Failure
DSM
B2318
Mirror Passenger Vertical Feedback Potentiometer Short to Battery
DSM
B2320
Mirror Driver Horizontal Feedback Potentiometer Circuit Failure
DSM
B2322
Mirror Driver Horizontal Feedback Potentiometer Short to Battery
DSM
B2324
Mirror Driver Vertical Feedback Potentiometer Circuit Failure
DSM
B2326
Mirror Driver Vertical Feedback Potentiometer Short to Battery
DSM
B2477
Module Configuration Failure
DSM
INSTALL a new DSM.
bring up device manager, turn the device off, then plug into the computer, with finger on the + volume. it should prompt the computer to diagnose the problem, then you can click on repair, in the device manager. I had similar problem and this worked short term, but now it is happening over and over. I think the battery may not be as rechargeable as advertised. I have had this about a year and use it a lot, but don't want to buy another one. I cannot download music now, so have to call support. This should fix your issue short term
it does it because the battery is dodgy and is going to be on the news tommorow in the meantime i woulsd look on the sony website support and ask for a new one if that fails buy one in town
Hi you do not say where in the world you are? . if UK then this site
( www.BuySpares.co.uk ) list replacement battery for the gogear 6320. I have also seen the for sale on ebay
Here's a better solution - no offense, silly girl. First, find out if the computer will recognize the GoGear when you plug it in. If so, then use the Repair function in the Philips Device Manager.
If the computer doesn't recognize the player: Disconnect the GoGear from the computer, and turn the player off. Hold in the volume + button and continue to hold it as you re-plug the GoGear back into the computer. After 45 seconds to one minute, Windows will go into recovery mode and resucitate your player.
Also, the number for the Manufacturer - Philips - is
1-866-PHI-LIPS (or was it 1-888? - one of these is an adult line, the other is not) :-)
