Question about HP OfficeJet 6110 All-In-One InkJet Printer
My light will not come on when I try to scan or copy, do I need a new bulb?
2 Suggested Answers
  • 96 Answers
SOURCE: WILL NOT SCAN OR COPY APPEARS LIGHT BULB IS NOT
Go on www.hp.com put in your model number and troubleshoot!
Posted on Jul 27, 2010
Indicates warming up when you try to copy or scan anything
Lift the lid and check the scanner light when you attempt to copy or scan. If it is not lit, then that is your problem. This is a relatively old device, and uses a fluorescent lamp. These require a short warm-up time that will increase as the bulb ages and eventually the bulb will fail. At that time the warm-up indication will remain since the bulb never reaches temperature. Based on the age of the unit (first release 2004), if the lamp is bad, it would be prudent to get a new unit.
Sep 16, 2015 | HP Photosmart 2610 All-In-One InkJet...
Scanner light does not scan?
Have you tried replacing your bulb? Hope this helps.
Feb 13, 2013 | HP Photosmart C4280 Aio Printer
Bulb out
Are you saying that if you try to make a copy or scan, when opening the scanner bed cover, the bulb is not lit? If this is the case, then the scanner light "bulb" has gone defective now. Lexmark does not have a replacement for that part, you can try to have it repaired from 3rd party shops, otherwise, it's time to replace your printer.
Please try to contact Lexmark technical support center for other options.
Dec 17, 2011 | Lexmark P4350 All-In-One InkJet Printer
My copies and scans are coming through black as though its not scanning bright enough to pick up the print
If you try scanning with the flatbed open, can you see if the bulb lights up during scan? If not, (or if darker than usual) then your bulb is no longer good on the scanner. If the bulb is bad, it would most likely be cheaper to replace the whole scanner versus paying to repair/replace the bulb.
If the bulb is fine, I would perform a hard reset on the device. To do this: Press and HOLD all following buttons: Power, Load/Eject, Stop, B&W, Color. RELEASE BUTTONS. After this printer turns on, you'll see "Init eeprom" on printer screen. Press Color button to clear protection counter.
Feb 28, 2011 | Epson Stylus Photo RX520/RX530
When i try to make a copy it comes out all black and when I try to scan something it is all black
Check the scanner bulb - it's suppose to light up when you copy or scan. Look inside the scan bed and as you copy or scan, it should light and move across the bed.
Feb 01, 2011 | HP PSC 1610 All-In-One InkJet Printer
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
When i copy or scan it comes out black
You have a burned out fluorescent bulb,
You cannot buy a replacemrnt bulb. Sorry.
Oct 17, 2009 | Canon CanoScan 5000F Flatbed Scanner
Hp photosmart c6180 all in one printer will not scan or copy
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Mar 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
