Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
Is there a lint catcher on this washer? All of our clothing comes out with lint stuck to it, especially the t-shirts.
    Top Expert:
  • Whirlpool Master
  • 75,817 Answers
This washer has no link catcher
Posted on Sep 06, 2009
Testimonial: "Darn!! I was hoping there was one. Thank you for your help."
Top load GE High Efficiency washer has been leaving excessive lint on dark clothing. How can I fix this problem?
Clean out filter also spin clothes in dryer the lint catcher in the dryer will catch the lint.
Nov 15, 2014 | Washing Machines
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
Dec 05, 2010 | Maytag Washing Machines
All my shirts are ending up with fuzz balls . Is there a lint filter?? i can't seem to find it .
There is no lint filter. Make sure you have enough water to float the clothes. Try washing your shirts with the permanent press or gentle cycle.
Nov 20, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Clothes come out covered in lint after washing
Sears top load / direct drive washers don't have specific Lint Filters.
See the Use and Care manual for these washers for hints.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0705087.pdf
Apr 12, 2010 | Kenmore 24902 Top Load Washer
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Why does my washing machine leave lint on my clothes? does this type of washer have a lint catcher?
Most washers don't have lint traps, the dryers are expected to. In your type of top loader some simple traps would be located in the top cap of the agitator. They should be cleaned each load, but they only stop the bigger pieces.
Jul 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Lint on Clothes
When you wash clothes, they lose fibers from the agitator and unfortunately when you hang dry them the fibers from eachother or other articles of clothing stick to it making them look like they have lint on them. Drying them in the dryer removes this lint. I suggest drying them in the dryer and to prevent wrinkles hang them as soon as possible after dryer stops other than that I know of no solution in the wash for this problem. Good Luck.
Feb 13, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore washer always makes lint on clothes
yeah check my four boxes and send me an e mail at b4829@yahoo.com ref lint on clothes
May 22, 2008 | Kenmore 22422 Top Load Washer
Crosley CAWC529JQ1 top load washer LEAVES LINT ON CLOTHING
try washing on a shorter time as this washer may have too good of wash action and the lint is fabric coming off your clothing
add more soap powder and do not buy the cheapest soap as the soap is important in the washing cycle of your machine
towels that are not too soiled brobably need 6 minutes at most on wash
if this machine has a delicate wash cycle use that for tee shirts etc
water pressure is important in rinse cycles
do you have high pressure and water only trickles in check water inlets on back of machine where the hoses screw on
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Whirlpool Ultimate Care II GSW9650LW Top Load Washer Logo
163 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
