Question about Sony Cyber-shot DSC-S700 Digital Camera
DSC-S730 copy my picture to my computer? - Sony Cyber-shot DSC-S700 Digital Camera
  • Sony Master
  • 497 Answers
The procedure to transfer pictures to a Computer depends on whether or not the Camera has the capability of using Picture Transfer Protocol (PTP). If the Camera is capable of PTP (in this case; DSC-S730 - YES), set the USB mode in the Camera menu to PTP and then use the PTP procedure to copy the pictures to the computer. Otherwise, use one of the standard USB transfer procedures.
This procedure must be performed while logged in as Administrator or to an account with Administrator rights:
  1. Turn on the Computer.
  2. Turn on the Camera.
  3. Insert the recording media containing the pictures into the Camera.
  4. Set the USB connection or Transfer mode setting in the Camera menu to PTP .
  5. Use the USB cable supplied with the Camera to connect the Camera to the Computer. NOTE: Connection through a USB hub or other USB device --such as a printer or keyboard-- is not supported and cannot be guaranteed. The Camera should be connected directly to a USB port on the Computer.
    NOTE: The Scanner and Camera Wizard should automatically start.
  6. In the Scanner and Camera Wizard window, click the Next button.
  7. Under Choose Pictures to Copy , do one of the following:
    • Click to select each picture you want to copy.
    • Click Select All to select all the pictures for copying.
    NOTE: Selected images will be marked with a green check mark.
  8. Click the Next button.
  9. Under Picture Name and Destination , in the Type a name for this group of pictures field, enter a name for the folder where the pictures will be saved.
  10. Next to the Choose a place to save this group of pictures field, click the Browse button.
  11. In the Browse for Folder window, click to select the location on the computer where you want to save the pictures.
  12. Click the OK button.
  13. In the Scanner and Camera Wizard window, click the Next button. NOTE: The pictures are copied to the Computer.
  14. After the transfer process it finished, under Other Options , click to select Nothing, I'm finished working with these pictures .
  15. Click the Next button.
  16. Click the Finish button.
If you are still unable to transfer pictures, please switch the USB mode of the Camera to Normal or Mass Storage and try again.
After following the steps above, the pictures from the camera should successfully be copied to the computer. If for some reason the pictures did not copy, try using the method for standard USB picture transfer.
I'm assuming you are using the Windows XP Operating System in the Computer. If not then follow this link:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C116935
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Posted on Sep 06, 2009
Driver for sony cybershot dsc-s730
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 15, 2012 | Sony Cyber-shot DSC-S730 Digital Camera
Hi camera sony DSC-S730 donot install in windos 7 so tme camera don't appeare in the PC
You don't need to install your camera.
Aug 27, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
When I connect my Sony Cybershot DSC-S730 with the USB cable to my computer, it is not getting opened. I am not able to copy the pics to my computer. How can it be opened automatically?
Try NOT connecting your camera to your computer.
Aug 18, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
Lost sware disc. how can I download the DSC-S730 software?
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Jan 21, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
Em not able to connect my sony dsc s730 camera to my pc .. plz help me
Aug 13, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Cyber-shot DSC-S730 Digital Camera: how do i download pictures from dsc-s980 sony...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
May 18, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
How do u download pic on a computer for a sony cyber-shot dsc-s730
Feb 01, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Driver for dsc-s730
Any Software or Driver is not required to transfer the data from the Cyber-shot Camera to a Computer. Just connect it to the Computer using a USB Cable, Computer will automatically detect the Camera. After that, you can simply Copy and Paste the data from the Camera to the Computer. (the Camera will be listed in the "My Computer" or "Computer" window).
However, you can download the supplied Picture Motion browser Software from the link given below.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4598&mdl=DSCS730
Nov 25, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Camera to pc
Jul 06, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Uploading Pictures To The Computer.
If you are running Windows XP or Vista in computer, hook USB cable between camera and computer, power up camera, Windows will recognize it and install required drivers automatically, click My Computer, Removable Disk, click folder and copy picture files and paste in some where in computer.
May 14, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
263 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
