Question about Aloha Housewares (93645) Ceiling Fan
My fan is 3 months old and the fan will not go on high anymore, barely moves at all
    Champion:
  • 435 Answers
The switch is not good,when you put it on high it does seem to work because a wire going to the switch can be out of it,so you must take the switch out ,to connect the wire,Hope that help you
Posted on Sep 06, 2009
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
Dec 07, 2015 | Cars & Trucks
No air
The bushings need regular lubrication with silicone spray.
May 29, 2012 | Oreck Air Purifiers
My old ceiling fan capacitor has A B C D on the back , the new capacitor has 1 2 3 4, how do I connect the new one????
I just changed out an old ADCB (172-90-001 / 1-81-M) fan speed switch with a L123 3 speed switch (Westinghouse 77286). My fan was only 2 speed but the 3 speed switch was all the Home Depot had in stock. So I knew I would have OFF occurring twice in the pull sequence. Its an old Hunter fan that came with the house.
A-Unused
B-Went to 1 (Blue Wire)
C-Went to 2 (Red Wire)
D-Went to L (Black Wire)
I originally put B (the Blue Wire) into spot 3, leaving 1 unused. But that made the pull order go OFF-OFF-LOW-HIGH.
So moving the Blue Wire to the 1 slot resulted in OFF-HIGH-LOW-OFF
Hope this helps!
Apr 01, 2012 | Dryers
Fan is barely running. during cook, fan runs weak and vent fan does not run. tech said maybe a control panel? i can do the work but need a parts and service manual. are these available? does the weak...
probably a defective motor or slipping blade. i'm not sure how old your amana is. if it's the real old chrome metal '70's or early '80's vintage models, the part may not be available anymore.. they were very common to fail.
May 16, 2011 | Amana Radarange Microwave Oven
My Thinkpad G41 does not boot up, nothing comes up
Hello
Have you tried swapping out ram modules? This would probably be the cheapest. And, a faulty ram module gives a beep code. Try it, and let me know.
Kind regards
Andrea
Apr 21, 2010 | IBM ThinkPad G41 Notebook
05 chev silverado fan wont turn off
Replace the blower resistors/relay. It is one piece, they are made together.
Feb 26, 2009 | 2003 GMC Yukon
Thermastat and furnace
you should have 24 volts between yellow and white wires at the stat when the stat is set to heat and set as hot as it will go. burners should light first then 3 to 5 minutes later the fan motor should fire up. if burner doesn't light check the wires going into the top of the gas valve see if you have 24 volts arriving there from the stat. if you do then the gasvalve is probably bad. you can bypass the action of the stat by jumping red to white on 90 percent of the stats made and in a few seconds the gas valve should click open gas flow to main burner where pilot ignites it. another easy check you can do is flip stat fan switch to on. fan should come on at once. if not then you have either no high voltage to unit or no low voltage ( as in a bad transformer). if the fan comes on you know you have high volts and low volts...by cover i assume you mean the decorative cover but there second cover with the mercury bulbs and all is still there. if you have only the bare subbase then new stat time. sounds like an old furnace if it has a standing pilot, it should be checked for cracked heat exchanger by a pro with a n electronic carbon monoxide detector. NOT a diy item due to the real danger of co poisoning.
Oct 02, 2008 | Kitchen Appliances - Others
Hunter ceiling fan barely moves
hi
check if the fan turn freely if not then it is most likely a stiff brg,if it does then it could be a capacitor failure or faulty winding in the motor
cheers
grantsreps
Sep 28, 2008 | Hunter (25417) Ceiling Fan
My hunter douglas fan has a remote which we use for everything. There are three settings on the remote when we push the one for high the fan is barely moving.It moves very very slow on all of the speeds....
I have the opposite problem.  My fan turns on during the night at high speed and sometimes turns on the light,too!  I've changed the frequency 3 times, but have to pay someone to do so, so I've given up and just unplug it at night.  My problem, so someone tells me might be that mine is not grounded.
Jul 04, 2008 | Heating & Cooling
Aloha Housewares (93645) Ceiling Fan Logo
52 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
