Question about Car Audio & Video
I need help installing a 4 Channel Power Acoustik Amplifier to Two Pioneer Subwoofers. I hooked up the power wire to the positive battery terminal in the engine compartment. I then cut the power wire and connected each end to the in-line fuse holder which is mounted by screws in the engine compartment. The poer wire then runs through the door hinge attatched to the engine compartment under the carpet to the trunk of my 1999 Mercury Cougar. I screwed the power wire properly into the 12 volt input on my amp. I bought a brand new Kenwood radio with 4 RCA cables but I only utilize 2 that run to the Amplifier. I also spliced the blue wire with a black stripe to the REM or the remote turn on wire.I have properly grounded the Amp to a large metal bolt in the trunk under the carpet. I have checked all the fuses and the are perfect. I have the subwoofers wired positive to positive and negative to negative as displayed in the schematic that came inside of the Amplifier manual I bought. The Amp indicator light is red which indicates that it is in protective mode and green power light has not once come on! It is a 1600 Watt Power Acoustik Amp and Two 350 nominal power each Pioneer Subwoofers. I have a box that the subs are contained inside as well. Please help me diagnose this issue.
  • rwood004 Sep 07, 2009
    I would like additional advice on my problem!
  • 3,741 Answers
Connect ampere in parrel way . connect it in parrel, an run ur power wire to ur battery (red wire) ur power turn on lead an rca cables to ur cd deck, ur ground wire (black) to a solid ground, any slid metal in the car . run ur speaker wires negitive to negitive terminial of the amp an positive to positive in parallel. ------------ Just run the positive terminal from one channel of the amp and opposite channel's negitive terminal to one sub. Run the 2 remaining terminals (the positive of one channel and the negitive and the other) to the other sub. That is how you bridge, but then how you acutally connect to the sub depends on how you want to wire (series or parallel). If they are DVC subs (dual-voice coil: two pairs of positve and negitive terminals on an individual sub), then it's best to run in parallel to get the post power. To do this, individually hook each bridged channel separtly to one pair of the +/- terminals on the sub, then from that run more wires to the other +/- terminals on that sub. Do this separatly on each sub. --------------- another way is -------- Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms. Bridging a 2 channel amplifier when using two subwoofers will supply the same amount of power to each subwoofer. It will simply be divided from the 2 channels wattage , then supplied to your two subwoofers. To bridge an amplifier, if it is a 2 channel, you would take a positive and a negative from each channal and wire them together making 2 positive wires become one positive wire and 2 negatives wires become one negative wire (twisted together); then connecting the positive to the far left (channel 1) of your amplifier, and the negative to the far right's negative terminal (channel 2). You need to make sure that the impedance is going to be stable once bridged too. Usually a dvc 4 ohm subwoofer pair can be wired series/parallel to establish a final impedance of 4 ohms bridged.
check out.
--------- thanks .keep updated.
Posted on Sep 07, 2009
  • 311 Answers
Hello their, I have reviewed your post about the 4 Channel Power Acoustik 1600 Watt amplifier not going out of protection mode, it's a class a/b amplifier so it's porbably best not to run it in bridged mode 2 Ohm Stereo, 4 Ohm bridged. this amplifier has overload as well as overheating protection. a quick test to check that the amp is working properly is to take a jumper wire from the power side of the amp, and connect it temporarily to the remote side, this is only to test. if you left it their it will drain the battery as the power on the stereo remote wire turns the power on the amp when it is powered. another thing that happens is that the ground looks like it is good but theirs so many factors at play with a good solid ground. the misconception is it only needs to be connected by a thread. meaning 1 or 2 strands of wire, not true at all, the negative cable is very thick often, this is because the power flows threw the ground as well so it would be very wise to check that the ground is connected to the chassis. something else that will help you is to test only one side the the speaker at a time. meaning of course hook left or right up to the amp and see if their is anything. sometimes the speakers are wired in series if this is the case then that will not work, but it may prove that the amp was wired from say positive terminal to negative and causing an interanl fult protection circut to cut the power to the mosfeats before they overloaded. theirs a verry good chance from this description that their is a + speaker wire going to a negative terminal with 2 speakers. low-impedance loads will cause issues say short circuits or backwards wiring. they can happen and not even be oblivious till you look at the speakers configurations.
  • 784 Answers
You are doing right on what you described. I really like to work with a clearly described what involved in an issue.
Now we have to use a Voltmeter to check if there is power to the amplifier. If there is power to the amplifier terminal, then the problem is at the amplifier, not the connection. Let check it out:
1- Turn on your Kenwood radio, make sure to hear sound from your regular speakers.
2- Turn remote control knob to the mid level between min and max.
3- Measure the blue wire where you spliced to ground to see if you have 12V, if it is not then the problem is right there.
4- Measure the Red wire power from the Amplifier to ground ( the bolt that you connect the negative power to see if there is 12V, if not trace back to the Fuse that you inserted between the positive terminal of the battery and the wire going through the firewall to correct it.
5- If you have 12V at step 3 and 4, then you have a defect unit, return it to the manufacturer for a replacement.
Posted on Sep 06, 2009
How to install a power acoustik 30th anniversary version series 4 channel 1200 watt amplifier
Power to battery. Ground to something in trunk. Remote to blue lead on radio. Rca to line or sub out on radio.
Sep 14, 2017 | Power Acoustik Car Audio & Video
How do I hook up three pioneer 12's to dual voice coil
run it through a 4 channel amplifier with seperate RCA connections. make sure to use a low gauge power (red) wire to power both subs.
May 02, 2011 | Car Audio & Video
I have a power acoustik 0V4-1200 amp and 2-12" kicker cvr dual 2 ohms. My amp keeps getting really hot and turning off. I have two pair of rca jacks from my cd player to the amp. One speaker hooked up...
i have found the specs to your amp. 1. Amplifier connections: Lets make things simple. As we look at the amplifier speaker connections, we will number the outputs 1 2 3 4 from left to right for the top connections and again 5 6 7 8 from left to right for the bottom connections. 1 should be connected to a positive (RED) (+) on sub woofer A on voice coil (a) 4 should be connected to a negative (BLACK) (-) on sub woofer A on voice coil (b) Now using a small piece of cable, connect negative of voice coil (a) to positive of voice coil (b) Follow the same procedure for the other sub woofer using 5 and 8 as 1 and 4 This configuration should make the amp run at 4 OHM BRIDGED x 2. i hope this helps. dreamsystems
Feb 07, 2011 | Car Audio & Video
I need a wiring diagram for installing 2 LT980-2
do you need help just for the power or for the audio or both?
power it is simple
positive goes to the battery but with a fuse in the middle
negative goes to a metal ground point on the car (but not battery)
remote goes to the radio with should have a blue and white cable if radio does not have remote line then use the acc wire from radio
for sound
your amp does two speakers and im guessing you want the back ones amplified
so cut the 4 wires that come from the radio and goes to the back speakers 2 positive and two negative
and connect this to the input the phono terminals on the back (unless your radio has phono terminals for audio out on the back side
then take the output from the amp and run it to the speakers one positive and negative to each speaker
i cant seem to find a wiring diagram for that amplifier but i can give you a more genral diagram
http://www.caraudiohelp.com/how_to_install_a_car_amp/how_to_install_a_car_amp.htm
Jan 05, 2010 | Power Acoustik LT-980/2 Car Audio...
Power Acoustik PWM-16 Equalizer Help
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
Hooking sub up
Hello missywarden,
According to the specifications, the amp is capable of "tri-mode" operation, that is, running normal speakers on the individual channels while also powering a subwoofer in bridged mode.
Your sub needs to be a minimum of 4ohms and should be relatively efficient. I'd look for a sub that has an RMS power range of from about 75 watts up to a maximum of 250 watts.
The sub connects to the leftmost speaker terminal (positive - right channel) and the rightmost speaker terminal (negative - left channel).
It's not going to be a really loud subwoofer. The power is 360 watts RMS which will be shared by the normal speakers and subwoofer.
Hope this helps.
Aug 05, 2009 | Power Acoustik TS620-2 Car Audio Amplifier
Sub woofers and amp
first of all is the amp a four way amp? if so then you need to know what the watts of the subs are (you dont want to melt them) wire + and - of channels 1 and 2 to one sub and + and - of channel 3 and 4 to second sub, nice thick lead from battery positive (fused) to positive terminal on amp thick lead from a good earth point to negative terminal on amp run a set of rca leads down the opposte side to the positive wire to prevent interference, run thin wire from remote wire of radio to the remote terminal of amp, rca's are plugged in at stereo and at the am. may need a RCA splitter to be able to power all four channels
Good luck Davelee
Mar 24, 2009 | Car Audio & Video
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Power Acoustik TS620-2 Amplifier
Check the wiring at the speakers themselves. It's possible that while you were moving the box one of the speaker wires came loose and shorted against the other terminal. A shorted speaker wire or damaged speaker will cause the amplifier to go into protect mode. If you have a digital multimeter with a resistance feature, you can test the resistance between the positive and negative terminals for each speaker.
Feb 26, 2007 | Power Acoustik TS620-2 Car Audio Amplifier
Car Audio & Video Logo
208 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
