Question about Frigidaire GLTF2940ES Front Load Washer
Removal of front lower panel
How do you remove the front lower panel on the machine to gain access?
My similar machine has two screws on the bottom. Remove and out it comes.
Posted on Dec 29, 2007
Washer out ballance
Hi Joe
Check lower balance springs, remove front panel to view there are 6-8 of these, to gain access and remove the front cover, insert a knife or thin blade approx. 4" in the from each side in between the seam on the front panel, this will release the top cover clips and the top cover can be hinged up and back. undo the two top screws to remove the front panel. Also check drum is rotating at full speed when spinning, if not spinning at full speed check and replace drive belt.
Dec 03, 2013 | Admiral Washing Machines
Dryer noise
First check the tumblers inside the drum to make sure that none of them are loose. AFter that you'll need to gain access to the inner workings of the machine.
There are 4 different designs that used on these dryers and each one has its own specific way to access the element, blower, fuses. etc In this FAQ I will describe each design and method to access for each one. ---------------Design 1: This design for this dryer has the heating components located in the front of the machine, which means to gain access you'll have to lift the top and remove the front. You can visually verify this specific type because the lint screen is located inside the dryer requiring you to open the door to gain access to it. As with any do itself repair, always unplug the machine before you start. Here's the method of access listed in numerical order. 1) Remove the lower kick plate by pressing in the two clips, one on each side located in between the upper and lower portion of the front In doing this you'll gain access to the element, located on the right hand side facing, the high limit and thermostat fuse located on the element, the cycling thermostat, located on the blower housing, and thermal fuse, located next to the cycling thermostat. In gas models the gas coils and ignitor may be located on the left hand side facing. If changing the belt, rollers or motor, continue to step two. 2) Lift the top by placing a flat head screwdriver in between the front and the top of the dryer and pry it upwards. In some cases there are two metal clips, one on the left and one on the right, that need to be pushed forward to lift the top up. 3) With the top up and the kickplate removed take the door springs off, one on each side, and remove the door by taking out the 4 screws one upper left and right, one lower left and right, off and don't forget to disconnect your door switch-----------------Design 2 : In this design the heating components are located in the rear of the machine. All you have to do is get behind the dryer, remove the 9 1/4" screws and remove the panel. The element eill on the right had side with the two fuses located on it, the cycle and thermal fuse will be on the lower left on the blower housing. To access the belt, rollers etc, remove the lint trap on top, take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off.--------------Design 3 : In this design the components are located in the front of the machine, but to access them you'll follow the method used in design 2 for accessing the belt, rollers, etc.take out the two screws that are underneath it and using a flat head screwdriver pop the top up. Next, located the two screws that are on the upper left and right inside front of the machine that hold the front. Remove these and then you'll be able to lift and pull the dryer front completely off. The set up will be like design one.--------------- Note: The best way to determine if your dryer is desgin 2 or 3, remove lint trap and pop the top. When you've got this done, you'll be able to look in between the inside rear wall and the rear panel and see if the element, fuses atc are there. If not it will be design 3---------Design 4 : HE, HE2, Duet, etc the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed. From there you'll remove the kickplate in come cases by taking the 3 or 4 screws off located at the bottom of the kickplate. With that removed you will be able to remove the front, but only after you remmove the control panel. The In some cases the components will be located in the rear like the second design
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 20, 2012 | Dryers
Were does the LH mirror on a 2011 f-250 connect. Removed mirror but disconnect is located some were in door or body. need to know what needs to be removed to gain access
  1. Remove the front door trim panel.
  1. Position aside the front door watershield to gain access to the exterior rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel similar.
  1. Remove the sail panel.
    • If equipped, disconnect the electrical connector
  2. If equipped, lift up and remove the exterior rear view mirror control switch panel.
    • Disconnect the electrical connector.
  1. If equipped, lift up and remove the window control switch panel.
  1. If equipped, remove the window regulator handle.
    1. Position the window regulator handle cover aside.
    1. Remove the window regulator handle screw and regulator handle
5.Remove the door trim panel center screw cover
6.Remove the 2 door trim panel center screws
7.Remove the 2 door trim panel lower screws
  1. NOTICE: Do not pull directly outward on front door trim panel as damage will occur.
    • Lift upward to remove the front door trim panel.
  1. NOTICE: Insert the lower panel tabs first or they can break when installing the front door trim panel.
    To install, reverse the removal procedure
Feb 20, 2011 | 2011 Ford F-250 Super Duty
Have to replace door lock #8182634 and need instruction on how to take the old part off
This article shows step by step photo instructions on how to replace the door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
  • Phillips head screw driver
  • small socket wrench
  • 7mm socket
  • replacement door boot seal
  • lots and lots of patience
  1. replace-front-load-washing-machine-1.1-120x120.jpg remove dispenser Unplug washing machine and remove dispenser.
  2. replace-front-load-washing-machine-1.2-120x120.jpg Remove lower front cover by removing 3 screws holding it on bottom. Remove lower front cover by removing 3 screws holding it on bottom.
  3. replace-front-load-washing-machine-1.3-120x120.jpg Remove screws connecting top control panel to front of washer. Remove screws connecting top control panel to front of washer.
  4. replace-front-load-washing-machine-1.4-120x120.jpg Completely remove control panel from front panel. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off.
  5. replace-front-load-washing-machine-1.5-120x120.jpg Use bungie cord to tie back control panel. Use bungie cord to tie back control panel.
  6. replace-front-load-washing-machine-1.6-120x120.jpg 'Pop' off the tension spring being careful not to bend or break it. Feel for the tension spring which tightens the door boot seal onto the front panel.
  7. replace-front-load-washing-machine-1.7-120x120.jpg pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer. With tension spring removed, pull door boot seal away from front panel.
    On GE models, pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
  8. replace-front-load-washing-machine-1.8-120x120.jpg remove inner tension ring IMPORTANT: Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In. Phillips Screwdriver) to loosen the inner tension ring via its clamp screw.
    NOTE: you may have to remove the front panel to gain access to the tension ring. If that is the case, remove the front panel by removing the screws positioned at each corner (four screws total). On some models you may have to first remove a lower-front panel to gain access to the bottom two screws of the main front panel.
Dec 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do i replace the door boot seal?
j
  • 7mm socket
Dec 04, 2010 | General Electric WCVH6800J Front Load...
Is there a filter on a wma56 washing machine, if so where is it
The filter is located at the rear of the washer, to gain access to it, remove the lower rear panel of washer.
Remove large black hose from bottom of drum, and remove and clean plastic filter inside the hose.
Refit filter and hose, and test .
May 04, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Code ld slow to drain
You do not state a model, or even a brand name, but ld normally means Long Drain, and generally is caused by a build up in the filter just before the pump. On many washers, there is a filter access on the front lower panel of the washer. Other brands require the lower section of the front panel to be removed to gain access to the filter.
Aug 15, 2009 | Washing Machines
Getting to water pump
To gain access to the pump, remove lower plastic cover at front by prising down with a screwdriver, and remove same.
You will see the pump pre-chamber cover, unscrew it anticlockwise,and check for anything in there .
Refit cover and refit plastic panel.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Indesit W 123 Front Load Washer
Maytag Neptune MAH6700AWW cant find door release
thats a good one, lookin up the service manual, it appears that your particular model has a manual release on hte lower section of hte latch assembly itself, and the only way to gain access to it, is to open the door boot/bellow, but obviously with the door locked that's not going to happen, i would try to gain access from underneath but by the looks of it that to is also closed off (solid bottom). id does show a model with a separate access panel(lower 1/4 of front of machine) however i am to assume that your unit has 1 solid front panel no access to remove.sorry i couldnt have better news. And the "pull" in the dispenser is no tere previous neptune frontloaders not pertaining to your machine at all!
Dec 11, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Admiral heavy duty washer - cleaning filter
Aw22 doesn't have one, remove the front panel to gain access to the pump, To do this insery a flat knife between the top panel and the front panel 4" in from each side to release the clips.
Unclip the two hoses to the pump after draining the machine, lower the external waste hose to floor level to drain.
tilt the machine back to remove the belt.
Remove the 3 bolts for the pump to remove and clean out.
refit in reverse order.
Jun 05, 2008 | Admiral AW22 Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
147 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
