Question about BenQ Computers & Internet
LCD monitor display troubleshooting benq e900wa
LCD monitor display is blank
  • GBMaker May 11, 2010
    Can you still see a an image if you look at the screen under bright light? Many times, the backlight in an LCD will go out, but the image will still be there.
  • BenQ Master
  • 32,281 Answers
Check the video cable, make sure it is not loose. Try the monitor on another computer to see if it works.
If not then follow these instrucrions :-
When the LCD monitor display is dim or flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Posted on Sep 06, 2009
SOURCE:
My benq lcd fp767 have power but no display,,,i want have a troubleshooting guide about the lcd,,,pls help me
First check the vga cable, video cards of your pc.if all of these are ok open your LCD monitor check the power board for boated capacitor, open secondary pico fuse or fuseble resistor, replace it with the same value. The defective lcd panel can cause of dim dispaly but the power is ok.
Oct 03, 2010 | BenQ FP767-v2 - 17" LCD Monitor
My samsung syncmaster 920nw requires to be degaussed but there's no degauss button on it. It is displaying colourful rainbows in blank areas of the image.
kanwaldeol, No need to degauss an LCD monitor. Only degauss CRT type monitors!!! Could have fractured lcd glass panel. 12fixlouie
Jan 28, 2010 | BenQ P992 19" CRT Monitor
Monitor displays desktop for a short while
this kind of trouble is very common to all LCD monitors. your inverter is shutting down. please check all capacitors at the power supply some are badged or blown on top due to hot pressure inside.
Aug 17, 2009 | BenQ FP71G 17" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
BenQ Monitor ' Out Of Range '
check your resolution settings and change to 800><600 and try again.If it does not work at 1024><768 try loading monitor driver In display properties it should show BenQ FP731 instead of plug and play monitor.
Samir
Oct 29, 2008 | BenQ FP731 17" LCD Monitor
BenQ LCD DV3250
Hi...there,
Well, have you try plugged into a different port like a DVI port. If you don't got one try replaced with another VGA cable.
Sep 26, 2008 | BenQ FP71G 17" LCD Monitor
Problem with moniter
i have BENQ lcd 15" monitor, the problem is that the menu appear atomaticaly
Aug 25, 2008 | BenQ FP71G 17" LCD Monitor
Benq 17"Lcd monitor fault
Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
Also check with Benq ,Normally offers three year warranty.
Samir
Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
LCD monitor went blank
Which model is it?Does power led remain on?
Samir
Jan 22, 2008 | BenQ FP737S-D 17" LCD Monitor
Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
Open Questions:
Computers & Internet Logo
670 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Joaquim Martins
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
