Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
My Apps won't come up, it keeps saying try reinstalling or restoring the file. But it doesn't give me the option.
My acer tablet screen froze after I accidentally deleted apps that I don't need. How can I fix other than buying a new tablet
First, try rebooting. If that doesn't fix it you may consider restoring the device to the original factory settings. A word of warning...restoring to factory settings will take the tablet back to the way it was when originally purchased. All passwords, updates, music, photos, videos, audio recordings, apps and so on added after it was purchased will be deleted. So don't do this if you are concerned about losing the aforementioned data and files. To do a factory reset go to settings and look for a restore option. It may be under something like system restore, device settings, back up and restore or something similar. Once you find it, it should warn you that your device will be restored to factory settings and that all post factory apps, passwords, data and files will be deleted. If you still want to restore your device follow the instructions. You will then have to set everything up from scratch as if it was just purchased. I did this with a Kindle Fire. After the factory restore I reinstalled my apps, added all my accounts (email and so on), downloaded all my books, music, etcetera, and it has worked great since.
Jun 18, 2017 | Acer Tablets & eReaders
Hi I just got a tablet online and it doesn't have
Just make sure with the play store settings, whether you have sign in with your G mail account or not. If no just sign in and try else register as a new user and try. If found still there were an error. Just try to restore the tablet. If you again found the same error then, shutdown the tablet and press power + volume up button up to 15 seconds, so that you will get restore option there and restore through that. Definitely it will work for you.
Aug 01, 2013 | Tablets & eReaders
My tablet reads my new sd card, but wont allow me to move any apps to it, and constantly says 'low space'. ive deleted all the apps i can with same results. plz help?
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPad will erase everything on it, so make sure everything on the iPad is stored elsewhere prior to restoring. To restore, connect your iPad to a computer with the latest version of iTunes installed. When your iPad appears under the devices menu, click the restore option under the summary tab. If you haven't backed up your data already, choose the back up option from the pop up window. Click the restore button to restore your Touch to factory spec.
God bless you
Feb 25, 2013 | Computers & Internet
I tried installing some apps on my phone Samsung b7330 but it the phone doesn't see any .jar or .jad files . i tried installing apps i downloaded from the phone's browser but when i try to open...
let try for some Jad file to make sure the problem.. suggestion: use sktool to repair and maintain your phone then reinstall the jad file.. or reinstall the fresh Rom from Samsung web page. good luck
Jun 01, 2011 | Samsung B7330 Cell Phone
I have a Tim Hortons E70006 Wince series netbook, when i click on the internet it says, " Application iesample.exe encountered a serious error and must shutdown.", why isnt it working?
When you turn your laptop on start taping f8 at the same time.The screen will come to a screen that gives you some different options.Use the the up arrow button And highlight safe mode.Hit the enter key.The next screen will give you the option to go into safe mode by choosing yes or doing a system restore if you chose no.I would do a system restore which gives you to pick a bold date on a calender which are different restore points(XP)Vista? I think is the same as Win 7 only go back to the last restore point. You more than likely downloaded an incompatible file that is causing the problem.
You can try to repair your system with the system restore disk that will leave your personal files intact and attempt to fix the system files.If this doesn't work.A full system restore is your only option.Some operating systems come with a restore disk while others have a separate partition on the hard drive.I would suggest you have a geek friend help you the first time or take it to a shop.
You may have to get a hold of of the manufacturer to find out how to access the system restore partisan.
http://www.ehow.com/how_4424376_install-operating-system-computer.html
Here are some free apps that I use.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=rb_content;main
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html?tag=rb_content;main
http://download.cnet.com/windows/3150-20_4-0-3.html?&filter=licenseName=Free&tag=page;page Smart Defrag
Make a back up after your squared away only takes 3 DVDs and you just put them in and your back in business.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
May 21, 2011 | Computers & Internet
Run my new anti virus which picked up a problem on somthing called OLEPR032.DLL and gave me the option to delete it which I did (God do I regret doing that). How I keep have a pop up saying that this is...
Open up the help in XP and type do a search for System Restore Wizard.
Follow the instructions and it will give you a choice to restore your system to the way it was at an earlier date. Choose a date from before the problem started. Any programs you have installed since then will need reinstalling but you won't loose any data.
It may also restore the virus in the dll but you can find another way to fix that apart from deleting the file.
If that does not work you can boot from your XP cd and choose the REPAIR option.
I hope this helps
Sep 13, 2009 | Microsoft Windows XP Home Edition
Reinstall windows vista Os
If you are having the a Dell Laptop there is an interrnal restore option where you can reformat your computer HDD and you can put it back to factory settings - Which is called as Dell Factory Image restore --To get in to this option You need keep tapping the F8 Key on the keyboard as soon as you turn ON the Laptop . It will take you to the advanced boot option -- From the List Choose the One which says Repair my computer ---Next you will be getting a screen where it will ask for the Keyboard Layout option Choose Engllish US and Click on the Next it will take you to the Window Where it says System Recovary Option . . From System Recovary option Click on the one which says Dell Factory Image restore that will restore your Computer back to the factory settings after formatting the hard drive ...After restoring the Computer to the factory settings system will restart and then the computer is good to go ...........
May 12, 2009 | Dell Inspiron 1525 Laptop Jet Black
Viral attack : transfered a file from a usb key
try to login into safe mode and try to restore... still not fixed means., format your hard disk and remove once the mother board battery and fix it back... reinstall os again., good luck
Jun 16, 2008 | Acer Computers & Internet
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
27 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
