Question about Eureka High Filtration s Mighty Mite Enviro Vac Vacuum
Envirovac kicks debris back at my feet and is loud
My Envirovac doesn't seem to be working anymore. I have to make many passes before it picks everything up. It tends to kick debris back at my feet, and it's gotten very loud.
  • 175 Answers
It sounds like you may have build up in the fan chamber of this machine. If dirt gets building up on the fan it can cause a loud noise and reduce the suction to the floor tool. The motor is serviceable and can be cleaned. It could also have a motor bearing going bad to be noise. Make sure to check the filters that are back behind the paper bag. They me be clogged as well.
Posted on Nov 20, 2009
    Problem Solver:
  • 10 Answers
It's clogged!
Many so-called "environmentally friendly" vacuum cleaners have multiple stage filters; the usual configuration is a standard filter followed by a HEPA filter or equivalent. Standard filters can be a paper bag or a bagless, removable container.
From time to time, the secondary filter will get clogged, so it doesn't matter whether you change the bag or empty the container, performance will not improve.
If you have access to compressed air, try removing the secondary filter and blowing it clean with a high pressure air nozzle. If that doesn't work, check the hose to make sure it's clear. If you are using a rug beater attachment, make sure it has not clogged at its inlet.
Posted on Sep 06, 2009
The vacume picks up dirt then drps it none goes in the bin what is wrong .
Clean out the hoses and your filters something is blocking it from getting into the canister or dirt compartment
Mar 04, 2015 | Vacuums
Vacuum picks up some dirt and debris but not all, and spits some back out?
Some blockage at the pickup or in the hose if it uses one---dirt etc being kicked back out is a clear sign of this----if it has a tube check that first, and if a head with turning brush do not miss looking for a blockage there.
Dec 11, 2012 | Eureka True Clean Upright Vacuum (Yellow)...
Brushes move but won't pick up anything
I'm sorry to hear you're having difficulties with your DC25. If the machine doesn't seem to be picking up as well as usual, and debris seems to be coming back out of the cleaner head, this is likely to be due to a blockage. The filters may also need a wash.
The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=1148&product=DC25-ANIMAL
In normal use, the filters should be washed at least once every 3 months as shown in the video below. Use cold water without detergent, and allow at least 24 hours for them to dry completely before replacing them.
This should resolve the issue, but if you'd like any further assistance or advice, please give our Helpline a call free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Feb 14, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
The cyclone will not work.
Sorry to hear you're concerned about your Dyson cleaner. If you're worried that the dirt in the clear bin doesn't seem to be spinning, I can confirm that the debris won't always spin. Sometimes it gets stuck to the side, or just held in place by gravity. This does not affect performance, and is nothing to worry about.
If your cleaner doesn't seem to be picking up as well as usual, you may need to wash the filters or check the cleaner for blockages. The easiest way to do this is to follow the steps shown in our online troubleshooting guide:
http://www.dyson.com/support/help.asp?article=1461&product=DC14-ANIMAL_US
If you have any further concerns about your Dyson, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you and provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Aug 14, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson Animal has good suction and works fine for actually picking up dirt, but when I use the vacuum with the roller, I hear a grinding/rumbling noise. Its only when I use the vacuum with the brush...
Trace the path of the suction into the tank and see if there is anything loose or ingested. Also, remove the brush and clean as best you can. Perhaps there is something caught in it. Lubricate where it makes sense with some WD40.
Oct 04, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vacuum is picking up very little. No debris is
I have the exact same problem. The beater seems to turn just fine and the dirt is getting picked up, on it just sits in the hose. I don't think it's the best because it seems find, but who knows? Please help.
Feb 16, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a loud noise coming from the vacuum. also doesn't pick up
Check underneath, behind the roller where the opening to the hose is. I had the same problem that was caused by a Lego lodged in the opening and when it was removed, the vacuum worked like a charm.
Jun 16, 2009 | Kenmore Progressive Bagless Upright with...
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Eureka High Filtration s Mighty Mite Enviro Vac Vacuum Logo
172 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
