Question about Fisher and Paykel Dryers
No heat on F&P DGGX1 dryer.
I have a DGGX1 Gas F&P dryer that doesn't heat at all but runs normally otherwise. It's about 4-5 years old. Gas supply good. Got the Service Summary out of the top console. If I'm entering diag. mode correctly, then no DRYING PROGRESS LED lights means no DTC's? Noted on your site info. about fragile Ignitor. Do you have normal resistance value for same? ( this ignitor about 75 ohms) or other diag. techniques besides resistance check or other suspect components and their specs for same symptom?
Thank you much.
Richard Bowman
  • rrrbow5 Sep 06, 2009
    Hello protek480,
    After putting the top deck, console & lid back on but leaving the front panel off for viewing. I plugged in the power supply, started the machine & saw the ignitor and noted it was not glowing. So I checked for power to the ignitor first; there wasn't any. Looking at the F&P wiring schematic, I then checked for power back to the "Manual Reset"(no power) to the motor control module "Mains/Relay A" terminal 1, orange wire(no power). I've removed the ignitor and visually inspected it for melting, fractures, etc. What should be my next steps? How can I test/decipher for the no power out of Motor Control Module? Can Sensor Module signal MCM to cut this power supply to the gas heater?
    Thanks,
    Richard
    Hello there,
    Letting you know that I believe I have the fix pinned down. I jumpered the "Auto Reset Thermostat" terminals and the ignitor glows/heats & lights the burner. The faulty sensor/switch is open circuit all the time and this condition appears to cause the Motor Control Module to open the power circuit to the rest of the gas heater assembly; apparently for safety.
    thanks,
    Richard Bowman
    President:
  • 1,714 Answers
When dryer first starts, do you see the ignitor glowing? If not, change the ignitor. It yes (glowing) change the gas valve. That's it! The ignitor glowing indicates current flow to gas valve, and it should open.
Posted on Sep 06, 2009
  • Craig Butler
    Craig Butler Sep 06, 2009
    That resistance for the ignitor sounds good. It looks like the coil on the gas valve is bad and needs changing.
  • Craig Butler
    Craig Butler Sep 07, 2009
    Good job! Go to www.repairclinic.com and put in the model number and it will pull up all the parts for the machine. You can order it there!
The dryer is not giving any heat.
Sounds like the heating element has burned out. If it's an older dryer then that's probably the case. If it's newer I would check the warranty.
Feb 05, 2015 | Fisher and Paykel DEGX1 Electric Dryer
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
DOESNT HEAT AND I SMELL GAS
Hello - From what you are describing, if the dryer only heats up sometimes but provides a gas odor, it could possibly be a defective gas supply or igniter. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the fuse for the dryer. Turn on the dryer and select a normal cycle. If it proves to be ineffective and if the issue continues I suggest contacting a professional to move forward accurately. Keep in mind since it is such a complex unit, the technician will likely verify that it doesn't have a defective sensor, control board or high limit thermostat.
Oct 13, 2012 | Frigidaire GLGR341AS Gas Dryer
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
DGGX1 dryer doesn't heat up. Had to have the igniter replaced several years ago and the same symptoms now. Can the igniter be replaced without removing the panels?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Jul 09, 2011 | Fisher and Paykel DGGX1 Electric Dryer
Fisher & Paykel dryer, Model DGGX1 is not heating up
heatman101
Jul 08, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Loud squeak in DGGX1 Gas Dryer.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 19, 2010 | Fisher and Paykel DGGX1 Electric Dryer
Open Questions:
Dryers Logo
35 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
