I have a Carver C-15v preamp well it haves noise in the record player mode only. I need a schematic and help.
    President:
  • 1,348 Answers
Get a can of cold spray from an electronics industry supplier.
it cools to -51 f.
you have a bad transistor in the phono stage.if you spray it with freeze,the noise will go away.
i would just replace those transistors,
some have an op amp like a ua741 8 pin chip.
that will cause the same problem.
there is a fet version of the op amp,same problem.
if you get an audio tracer,you will hear the noise,and where it is coming from.
you can use an oscilloscope,but they cost 1000 and up.
you will see the noise waveforms.
Posted on Sep 06, 2009
I have a constant blinking ted light on my carver av405 amp can't get any sound out of it
The amplifier is in "protect" mode, possibly because the output stage was driven too hard or it overheated (thermal shutdown).
Nov 13, 2016 | Carver Audio Players & Recorders
Carver C11
Well, I also have some experience in old things.. Please let me know, does it have "rotary or slide switches" for selection of various inputs? if yes, kindly clean them with W-40 Contact Spray. I hope, problem will resolve there n then.
Aug 02, 2008 | Audio Players & Recorders
My carver HR - 895 was staticy at times on FM and all the sudden shut off. Now it won't Power up at all what do I do ?
Do you have an indicator light blinking or illuminated? If so, your amp has DC Offset, meaning a damaged amplifier. The static noise you heard, may have been DC voltage on the speaker output.
If you are interested in having your Carver repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Feb 10, 2015 | Carver Audio Players & Recorders
Carver TFM 35 amp what is the best way to hook it to a Marantz AV8003 pre app
No. You should use the line(or preamp output) to the Carver input. The only way you could use the tape output is if the Carver has input volume controls.
Dec 21, 2014 | Marantz Audio Players & Recorders
Carver power amplifier Pm1.5, 110 acv accidentally plug in to 220
magnetic field supplies are different than conventional types, check that the thyristor is working properly
Feb 23, 2010 | Audio Players & Recorders
I have a carver M 1.5 amp rt. channel is out.
Carver designs in general are not easy to repair. I would recommend that you send this unit into a Carver authorized service center. The likely problem is the output transistors, but the driver circuits and predrivers are not simple designs and if there is a problem there, it could effect the outputs. Tracing this will require equipment and schematics that I don't believe are available on the net.
Dan
Sep 04, 2009 | Carver PM950 Amplifier
Carver PM900 power amp with hum/buzz
1-shut down all flourecent lamp and check.
2-check for your cables in a good condition and no touching of wires to the body of amp.
3-connect(ground loop isolator)code number(270-054)from radio shack near you and connect it between your audio device(like cd player and amp)
Apr 15, 2009 | Audio Players & Recorders
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Carver home amp
The DVD system problably doesent have PRE AMP outputs..you can take the record outputs from the DVD system and use them to connect to the input of the power amp. You then will need o use the Carvers volume controls as the volume controls as the record output of the DVD system will be a fixed output set at 0db.
Jul 27, 2008 | Audio Players & Recorders
Carver M-400a schematic
You are not likely to find any Carver stuff for short money. What is the problem you are trying to solve? Maybe you don't need a schematic.
Dan
Jun 11, 2008 | Carver Audio Players & Recorders
246 people viewed this question
 Grubhead
Grubhead
