Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
My TV will not turn on!
My wega 32" will not turn on and gives 9 blinks. Should I trash it or can it be fix inexpensively? Thanks
  • 5 more comments
  • Anonymous Dec 10, 2007
    I have same problem. What should I do ?
  • nronaldo9 Dec 12, 2007
  • juderay Dec 13, 2007
    I have the 36" version of this TV. Same problem, 9 blinks, TV won't turn on. Repairman quoted $400+ to fix some electronic problem, so it's junk. My TV wasn't even three years old and I paid over $900 for it. I did not replace it with a Sony!
  • Anonymous May 10, 2008
    My 2 1/2-year old Sony 32" WEGA also stopped working ... fine one day, won't turn on the next. Red "stand by timer" light blinks 9 times. Sony tech support suggested unplugging from wall for 60 seconds. No fix, so she says it needs an "authorized service center to diagnose internal TV failing." Won't give further info on the meaning of 9 blinks. You can bet I won't buy another Sony!
  • sbandoo Jun 17, 2008
    My sony TV will not turn on, the red LED blinks 9 times. I tried resetting the TV by unplugging it and plugging it back into the wall AC. Pressed reset on the remote and still can't get my TV to turn on. What can I do without having to pay $500 for repairs.
  • roy2008 Sep 07, 2008
    9 blink times, I am shocked by seeing so many people has such fxxx issue .
    I have read the doc from VOTIT -
    Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
    anybody know where should I order the parts? and how much cost? is that worth? The set is very heavy, even I don't have idea if I can move it.it does not make sense at all for a two year TV to be dead.
  • leilanidecha Nov 27, 2008
    Same problem but blinks 5 times. tv only 2 years old . then just quit.
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Posted on Feb 06, 2009
I does too.. I called Sony and they said that they are not aware of the problem. Liars!!!!!
Posted on Oct 27, 2008
Use remote control:
display, 5, volume +, power
I can turn on my TV, though with the fault codes on-screen. Holp it helps.
Posted on Sep 07, 2008
Mine blinks  6 times   : (     it cant even manage 9 Blinks poor guy
Posted on May 18, 2008
Mine blinks but will start flashing a picture in 3 minutes. After 5 minutes of flashing picture it comes on and is perfect.
Posted on May 13, 2008
  • govno Jun 18, 2008
    Mine is blinking for about 10 minutes now before it comes on with a perfect picture. This has been doing this for 6 months. It's a 32" and 11 years old so it's not worth fixing but as long as it will finially come on why buy a new one. Just turn it on when you come home and by the time you get the dogs fed, get the mail, etc. it will be finished flashing.
Same problem my WEGA blinks 9 times wont come on, any help out there
Posted on Dec 09, 2007
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV won't turn on and standby light blinks 9 times... what can I do to fix this? Thanks, David
Nine blinks - Indication of shorted/leaky diodes - D6116 and D6301 on the "G" board. Panel Module Error or Thermal Error. Unless you are technically experienced, this can only be repaired by an authorised service centre. Obtain a quote for this, the parts are inexpensive, but labour costs might not be.
If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching IC regulator on the "G" board or check connections. Make sure the regulator is -12V or -13V (negative rail).
If the repair is done by an approved workshop, they will clear the error codes (standby LED blinks) as part of their 'soak-testing' and it should reset the TV back to factory condition. Remember to ask about what work was done and if the errors have been cleared/reset before you pay their bill.
Mar 27, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32.FS120 wont turn on and stand by flashes 5 times. Is this any easy and inexpensive fix or not worth the time and money since tv is 6 years old ?
5 blinks indicates that your system has detected fault on Chroma board (Chroma board is the only board connected at the rear part of CRT). Often there are loose connection on IC terminals. Re-soldering of ic terminals can fix your problem.
Oct 19, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinks
The blinking standby light should be in a repeating pattern of a fixed count of blinks. Please post that count here as that will indicate the circuit in which a problem was detected. Armed with that info, we can then tell you the problem and probable solution.
Thanks,
Dan
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32FS120 - 9 Blinks
I just fix one like this one for $200.00 usually is $275 you have problems in the zero cross detector inside the tv
Jul 25, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking 8 times
this kind of tv have a good picture if you use the component input
most sure you have problems on the zero cross detector or the flyback
I did one like this one for 200.00 if we need the flyback goes up to 275.00
Jul 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
32 wega trinitron
surprised it went 12 most 8-9 not Worth the fix
Apr 17, 2008 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
479 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
