Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Problem with Adaptive Defrost in Maytag refrigerator
I recently moved from USA to India and brought my Maytag refrigerator MZD2766GES with me. Its not going into deforst cycle and stops cooling every 3-4 days. India has frequent power outages everyday. Although I have my own power generation in case of a power outage, it takes 15 to 30 seconds to switch to generated power. Do you think this resets the adaptive defrost cycle and that's why its not going into defrost as temporary power outage happens every 3-4 hours.
If that's the case:
- Is it safe to turn off the refrigerator once a day for 2-3 hours to stop the frosting?
- I might consider using a UPS to cover the 30 seconds it takes to switch to generated power. What wattage do I need for the UPS?
- What if I install a switch from L1 and Test of the adaptive control and press it for 3-4 seconds once every day?
- Any other suggestion?
Thanks for your help.
4 Suggested Answers
SOURCE: MZD2766GES Maytag defrost problem
in fresh food part on top right, remove the housing assy.
Posted on Aug 07, 2008
  • 958 Answers
SOURCE: RESET DEFROST TIME
please check you model. if it is a new model. most likely it is now using the adaptive defrost which is controlled by the pcb. no more mechanical timer.
if you will find the diagram and it would say you have a timer. you can look at the front, if you take the front grill off. sometimes they are located at the center wall between the drain pan and the condenser.
tnx 4 using fixya,
drcool
Posted on Nov 05, 2008
  • 13 Answers
SOURCE: I want to replace adaptive defrost encl -- where
It should be located in the top of the refrigerator section in the housing where the temperature control it.
Posted on Jun 03, 2010
Maytag refrigerator moldel msd2756dew coils are freezing over
There are three magor parts that control the defrost on your model MSD2756DEW Refrigerator. The=> MSD2756DEW Controls are inside the fresh food compartment and behind the controls on the top shelf. In that photo is position 13 That is your ADC or adaptive defrost control part number=> 61005988
This is most likely the reason for not defrosting and causing the evaporator to ice over. The next part is the=> 61006199 Defrost Heater with Defrost Thermostat
sea_breeze_142.jpg Here is a PDF of a Maytag MZD2766GES and it has the same parts as yours so click here=> Maytag MZD2766GES Just use it for illistration or parts. Click here=> Defrost Heater Assembly to see that part and at bottom of page there is a short movie of how to test the defrost heater with an OHM meter. This is not hard to do if you want and I will be here if you need to ask other questions. If you have questions please let me know, Thank You, Sea Breeze
Apr 18, 2011 | Maytag MZD2766GES Side by Side...
MZD2766GES No cooling.Stat(slide) set to call.120v to unit.Lights on.No compressor operations.Manually defrost last few months.
Lets check start relay, run capacitor and thermostat. Also need you to pull away from the wall and unplug, remove cover over compressor and then feel the top of the compressor to see if warm or too hot to keep hand there. Should you need a start relay you will need=> 12002784 Relay and Overload Kit
12002784 Relay and Overload Point and Click Parts If the compressor is cool I want you to check the Adaptive Defrost control=> 12002104 Adaptive Defrost Control Sometimes these parts act like the compressor start relay and stop compressor and fans and even sometimes one or the other. The thermostat should also be checked while unplugged with an OHM meter=> 61005327 Temperature Control Here is a pdf with the locations and should you have any questions I will be here again later, Thanks Sea Breeze
Here=> MZD2766GES
Apr 16, 2011 | Maytag MZD2766GES Side by Side...
Temp is going up in both the fridge and the freezer droor
First place to look is the freezer and see if frost is building up on rear wall. If yes unplug and begin manual defrost. I am almost sure your has a Adaptive Defrost Control on the inside control panel where you set temperatures and if bad will set this problem into causing no defrost and having ice blocking air flow. I need to give many reasons for you to look for but it is what I do on service calls. Because your model has Adaptive Defrost Assembly Click Here=> 61005988 there is a higher possibility that it is defective and not allowing defrost. On link below it is photo #13 on that page. You will need to enter the control panel through the fresh food section above the top shelf. Please let me know what you find so we may move checking for something different like fans, start relay or run capacitor. If you need more answers or diagrams or photos Click Here=> Sea Breeze If you have any questions please ask, Thanks, Sea Breeze
Maytag MZD2766GES Control Panel
Dec 14, 2010 | Maytag MZD2766GES Side by Side...
Have a Maytag MZD2766GES Side by Side Refrigerator, somehow it just stopped working. The freezer part is just a little cold but the other side is not cool at all. What can it be?
check the freezer compartment, remove the shelves remove the cover in the back if the condensing coil is frozen solid your adaptive defrost board or defrost coil is bad. a temporary fix is turn off refrigerator, defrost coil ( I used a space heater). turn refrigerator off . you will need to do this every third day until adaptive defrost board is replaced. to check defrost coil check with ohm meter It should have resistance. this website should give you the gory details http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 15, 2009 | Maytag MZD2766GES Side by Side...
Not cold
Inside the fresh food compartment there is an adaptive defrost control. If it is bad it will cause the evaporator coils to freeze and reduce cold air circulation throughout your refrigerator. You can unplug your refrigerator and remove the control panel as to view the board. Sometimes you will see burn marks but not always. You also can while unplugged remove the back panel in the freezer compartment to see if ice is present and if so you can defrost the ice and examine the defrost heater to make sure that it is ok. The part number for your adaptive defrost assembly is 61005988
I am using the model number above your post so please correct me if wrong. Model number MZD2766GES
Go to link below, they offer free help and assistance.
Enter model number in the model and parts search feature. Thanks, Sea Breeze
When you get to the model page on left click picture #2 controls
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Maytag MZD2766GES Side by Side...
I need to know where the adaptive control defrost board is located in the fridge
In the top right rear corner of the control panel.
What is your problem?
BTW your fridge is on recall from Maytag.
Apr 13, 2009 | Maytag MZD2766GES Side by Side...
"maytag plus wide by side is not getting cold enough"
The defrost thermostat is failing on these machines as well as the adaptive defrost control.
The compressor start relay is on recall from Maytag also.
Apr 10, 2009 | Maytag MZD2766GES Side by Side...
Mzd2766ges
its located in the upper right corner of freshfood side. sometimes its hard to get to. remove light shield, then heat shield, then the auto damper housing assy. and then 2 scews holding the defrost board,remove the 4/6 wire plug to board carefully. also unplug refridgerator first. good luck.
Aug 27, 2008 | Maytag MZD2766GES Side by Side...
Jul 21, 2008 | Maytag MZD2766GES Side by Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
91 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
