Question about Nokia 3230 Cellular Phone
The Power went off and start blinking and got blanked
My Panasonic TC-P50VT25 just went dead (blank screen). The power light blinks 13 times. I also noticed that the fans are not running.
The power supply is the first place I would start on this one. You will have to meter the outputs to the other boards to verify this.
Jan 29, 2015 | Panasonic Televison & Video
Jvc av32d303 screen went blank power went off and timer light came on. eventually I starts flashing ever couple of seconds and never stops. Does nothing else
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 14, 2014 | JVC AV-32D303 32" TV
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Monitor is blinking and then went blank
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 12, 2010 | Emprex LM2201 22" LCD Monitor
No power to set but power button is blinking two pulses then stop
This can be a failure on any of the boards. The description is very general. The flashing LED indicates an error sensed during the start-up.
The service tech will determine the defective boards from diagnostics, and replace them as required.
Jerry G.
May 12, 2010 | Panasonic VIERA TX-26LMD70 26 in. LCD TV
POWER STAND-BY LIGHT KEEPS BLINKING
part# 191002393 is the thermal fuse.Located on lamp housing.
Aug 22, 2009 | Televison & Video
Our 52" widescreen LCD TV just quit working.
This set uses a lamp ( not picture tubes ) The part # is TS-CL110U. Almost certainly it is bad. They are easily obtainable and you can easily change it yourself.
Apr 09, 2009 | JVC HD-52G787 52" Projection Television
Sony KDF-46E2000 - Screen Goes Blank
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
Dec 06, 2008 | Televison & Video
Power indicator light blinking
Check soldered in micro fuses...F850, F851 etc.....
1) solder jumper wires on signal board = 008,010,017,048,600
2) Check / replace STK392-110 convergence IC's with Toshiba
part # 23135090 or upgade to Hitachi part # CZ01341
Let me know....................T.
Jan 04, 2008 | Toshiba 65HX81 65" Rear Projection...
Nokia 3230 Cellular Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
