Question about GE Energy Star WCVH6260F Front Load Washer
GE WASHER MOD.WPSR3100 DRIPS OIL HOW TO GET TO IT
GE WASHER MOD.WPSR3100 WOWW
    Sergeant:
  • 271 Answers
Your bearings are gone that's why you have oil you have a big job on your hands if i was you i would go down to your local second hand appliance shop they might take on the job and its not all the dear so try and ask first before wasting money doing it your self.
Posted on Jan 06, 2008
I have a GE WPSR3100 washer...need to know the cubic feet capacity size?? please help
According to a spec sheet I have from GE when we bought it eleven years ago the capacity is 3.2 cu ft.
Nov 29, 2010 | GE Profile WPSR3100W
GE Washer Mod # WJSE4150 click on spin cycle when fisrt engaging, seems to run & spin fine when in second/hiher speed.
Hi, since your washer is a "belt" drive, I'd suggest checking to see if perhaps the belt is slipping. While you're checking that, make a note of "oil" sprayed around the cabinet on the belt, pulley's etc. These generation GE units are known for tranny leakage/failures. If you're able to remove the front panel from the cabinet, you'll get a much more thorough look at your drive & basket/tub assembly. Just push in the 2 clips on top of the front panel on both sides with a puddy knife or narrow flat screw driver, and pull forward. The bottom just hinges on 2 hangers and the front comes right off. That's a start for now, hope it's a help. Let me know. Good Luck :)
Oct 28, 2009 | GE WJSE4150B Top Load Washer
My GE washer (mod WHSE5240D0WW) will not spin. It
sounds like the motor or the programer has packed up on you more (likley to be motor,) buzzing is the motor trying to turn but cannot,
Oct 26, 2009 | GE WHSE5240D Top Load Washer
GE. Washer MOD. WDSR2080DBWW will not stop
Bad water level sensor or tube connection going to control board.
Sep 06, 2009 | GE WDSR2080D Top Load Washer
My GE washer won't spin or agitate
check the motor capacitor if your motor doesn't turn when powered, otherwise the "wig-wag"coil could be faulty,these coils shift your transmission for different cycles
Aug 23, 2009 | GE Profile WPSR3100W
Drain hose leaks at junction in back of machine
If you find a solution let me know, I have a similar problem.
May 28, 2009 | GE Washing Machines
AGITATOR REMOVAL GE WASH MACHINE, MODEL WPSR3100
If you remove the top cover to the agitator, inside you will see a I believe 9/16" nut.  Remove this to take the agitator off the shaft.
Mar 12, 2009 | GE Profile WPSR3100W
Will not run!
the control knob is most likely to be out on it if you take it apart and get a part number it should be easy to replace call an appliance parts place. i had to do the same thing to my washer and it fixed the problem
Jan 13, 2009 | GE Energy Star WCVH6260F Front Load Washer
My GE washer Model WPSR3100 will run for 2 or 3 minutes when first started and then stop. After 5 or more minutes it will start up again and run for less than 1 minute and stop again for another 5 or more...
It appears that you may have controller issues since operation is haywire. Try to reset the electronics to factory defaults. If this remedy does not do it then.........
Search Over 2 1 Million Appliance Parts
Sep 20, 2017 | GE Washing Machines
GE Energy Star WCVH6260F Front Load Washer Logo
131 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
