Question about Audiovox GMRS200W (14 Channels) 2-Way Radio
BATTERY DOES NOT CHARGE AND CHARGER DOESN'T LIGHT UP
    Scholar:
  • 146 Answers
If your charger is plugged into the outlet properly and you know it does work with other batteries, what you have is an internal open in your battery.
I have seen this happen, not sure what would cause it, but batteries can open up inside. Could be as simple as a cold solder joint inside where the batteries connect to the leads mounted on the case or worse. Either way, that is most likely your problem. Time to get a new battery if you know the charger is good. Other wise if the charger doesn't light up for any battery, then you have a defective charger
Posted on Sep 16, 2009
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I was on the phone with my BB Torch, then the battery ran out, i got back the next morning, tried to put it on charge, nothing happen, no red light, no indicator , nothing, tried the charge for few ghours...
Good Day, Try this first and let me know what happens later. Use something like a needle to scratch the terminals of the battery and put your ****** to the terminals to make it a little wet. Then put the battery back inside the phone without connecting the charger to the phone. Then after the red light comes on, connect the charger. If the red light doesn't come on, connect the charger and put the battery inside. Please don't hesitate to let me know what happens later. Thanks for using Fixya!
Sep 09, 2011 | RIM BlackBerry Torch Cell Phone
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
Battery charger doesn't charge batteries. Light
Check the output on the adapter also check the voltage on the battery , If there is none then the particular unit needs a check. If the adaptor voltage is good then the battery can be faulty
Jul 11, 2011 | Cameras
My motoriola defy phone wont charge it has been at 0% charge all morning.
Hello and welcome to FixYa;
Take out battery, clean off the battery and gently clean off the terminals. Put battery back in and try to charge again with your charger. If this doesn't help;
Try another charger to the phone such as a car charger if you have one. If the battery still will not charge;
you may need to get another battery. I suggest you go into your local service provider first, have them use one of their spare batteries that fit into your phone model and see if the battery will start charging.
If it doesn't, you need to have your phone itself looked at instead of the battery.
Try these steps before you spend money on replacing parts needlessly.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
May 30, 2011 | Cell Phones
Just got a used unit and the battery does not seem to charge. When plug charger in light on charger is green. When I attach the battery the light goes off, and charger makes a humming noise. Is this...
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in, you can order a new one here www.powerwheelsoutlet.com
Aug 26, 2010 | Peg Perego John Deere Gator HPX Ride on...
Audiovox GMRS200W (14 Channels) 2-Way Radio Logo
122 people viewed this question
Top Audiovox Radio Communications Experts
eradiostore
eradiostore
john milligan
Computer Repairing
Computer Repairing
Are you an Audiovox Radio Communication Expert? Answer questions, earn points and help others
