Question about Maytag Washing Machines
I smelled rubber burning, it made a squeal and so I turned it off. The machine goes through all the cycles including spin but will not release the water. I turned the machine over outside to drain the remaining water. I tightened the belt on the bottom of the washer as it seemed loose. It made a noise like it was trying to spin but nothing happened. I shut it off and now it doesnt' do anything. Nothing smelled like burning.
  • 1,165 Answers
Sounds more like motor was seizing and making belt squeal.
Posted on Sep 06, 2009
Top loader smells like wirers burning and squealing when spin cycle starts
Hey Tara, I understand that your Frigidaire Top Load Washer is squealing and presenting a burning smell. Is this occurring every time you are using the washer or with random loads? Typically, when you experience the squealing and burning smell it indicates that the washer is possibly overloaded. I would recommend that you stop the washer and reduce the load. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 27, 2015 | Washing Machines
Maytag hav2558aww, made loud squealing noise upon the start of an agitation
Possible item caught between basket and outer tub. Remove the front panel and tub top ring. Shine a bright light around the semi-transparent tub and look for item. Check the pump pulley - ride the belt off and spin it by hand. If you feel any resistance or grinding replace the pump.
Mar 10, 2014 | GE Profile WPRE6150KWT Colossal Capacity...
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
It made a quite hum during the spin cycle, instead of the normal (much louder) spinning sound. When I turned it off I noticed it had a rubber/electric burning smell.
If it's a squealing sound, your belt is probably bad. If it's a humming noise with those smells you listed, it might be your transmission going bad.
Nov 02, 2009 | GE WBSE2090A Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Your washer has brake problems you need a qualified repair person
Apr 02, 2009 | Washing Machines
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
219 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
