Question about Dell Latitude D600 Notebook
Battery help i have a dell d400 latitude i purchased from ebay i put charger on and orange and green light flash even when i take off charger when i use it on ac adaptor its oky mild green flash and i also dropped it today can it be the battery needs replacement ?
  • 1 more comment
  • sabbriella Sep 06, 2009
    i dropped the laptop on the floor
    could it because i dropped the laptop ?
  • sabbriella Sep 08, 2009
    i just bought a replacment battery from ebay i don't know what you mean by rig will the replacement battery work or do u think it will be dangerous ?
  • 558 Answers
Yes you may have to replace it.Most dell batteries will charge very quickly after twenty minutes or so it should not show orange light at all.Question though can you power on with the battery only.If you can how long before you have to plug in the adapter.You can try this however it may or may not work,take a old toothbrush and clean the contacts on both the battery and the computer.Try again to charge the battery.
Good Luck
Posted on Sep 08, 2009
Testimonial: "thank you "
    Scholar:
  • 118 Answers
I had the same exact computer and my battery was out, yes you're going to have to replace the battery. Unless you can leave it on the charger all the time. But there's also a way you can buy new batteries and rig it up yourself. If you're not good with wiring things, just get a new one. But it's cheaper, but DANGEROUS.
Posted on Sep 07, 2009
Testimonial: "thank you"
  • Aron Sep 09, 2009
    No I meant going to buy new nickel-cadium batteries from the internet, they're just like AA's. But no, if you purchase the new one that just plugs in there's no danger. I guess I shouldv'e rephrased that. All you have to do is swap them and voila! :) By the way you're welcome.
    Brigadier General:
  • 5,158 Answers
Yes and what did you drop ?
Posted on Sep 06, 2009
Hi my Dell Latitude LS laptop isnt starting up or turning on and when i want to charge my battery the charger wont charge the battery and the green light only flash on and off every time i put the cable in...
Easy your battery is shot. Go to ebay and find a new one around $30. just enter all your info of ur laptop like Dell Latitude and should be a # with latitude.
Nov 02, 2010 | Computers & Internet
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
I have a DELL 400 with 600mhz processor - can I update the processor and to what speed ?
wanted to change cpu, but as soldered on motherboard - not worth the effort
Oct 16, 2009 | Dell Latitude D400 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Flashing Lights On My Computer?
You've changed the batteries, but are they fully charged?
I usually leave my charger in all the time when using the laptop as Advent laptops have bad battery life.
Try charging it for max 8hours. If the problem stil persists,then i guess its something internally wrong with the laptop?
Or even, the charger wire may be a bit loose which is preventing it from charging the laptop either completly or partly.
Hope that helped
http://stores.shop.ebay.co.uk/Sabka-Hosiery
Mar 10, 2009 | Dell Lattitude D600 Notebook
Battery replacement
There is a battery lock at the bottom of the laptop and u need to move that lock and battery pops out
Dec 26, 2008 | HP Espow----Replacement for COMPAQ...
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Batry
Try removing the battery and leave out for about 10 minutes. Put it in back and see if it works
Apr 16, 2007 | Dell Latitude D400 Notebook
Dell Latitude D600 Notebook Logo
94 people viewed this question
Alun Cox
