Question about Yamaha Full-Size Keyboard
How to resett yamaha motiff 88 to factory default
  • Yamaha Master
  • 5,603 Answers
Sir, have a Yamaha PSR 330, very recently the left speaker is not working. Do guide me for the same.
If it was playing fine and just stopped working while you were playing it, it's possible the speaker has failed, or a wire has come off. It is likely something you cannot fix yourself, and should find a local music store, like Guitar Center, who can repair it for you. It's generally not a very expensive repair at all.
If the sound stopped working from one side after you were playing with some controls or editing some voices, you may have set the panning all the way to the right, which would cause no sound to come out of the left speaker. In that case, you would simply need to set the panning to the center again while in editing mode.
If you are not too familiar with the editing features on the PRS 330, and not sure how to set the panning to the center again, you could always simply reset the unit to it's factory settings once again, while will return all the voices, effects, panning, etc. back to like the unit was when it was first taken out of the box and turned on. Here's the process to reset the Yamaha PRS 330 back to it's original settings -
Restoring the default (factory-programmed) settings While holding the C7 key (right-most key on the keyboard), press the power switch to turn the power on.
This operation erases backup data in this instrument (including backup settings in the Function mode) and
restores the factory default settings. The User Songs and the external Songs stored to internal memory will be
retained
None of that works and you do need to have someone look at the unit, here is a link to the Yamaha Authorized Service Locator to find the nearest authorized service center near you -
Servicer Locator
Sep 19, 2017 | Yamaha Music
When I turn on my Yamaha mo8 88 key music production synthesizer, it will start to turn on but as soon as the files begin to load, it just turns back off.Help?
I would bet on a failing power supply since the mere act of loading your files is causing it to shut down.
However, there is likely no circuit info accessible to us, you are stuck with Yamaha service and not knowing where you are located, advice is not possible.
Good luck-
Jun 04, 2015 | Yamaha MO8 88 Key Music Production...
Yamaha 9000pro, Ps is ok but unit will not boot
You may need to perform a factory reset operation. Turn power off, hold down the DEMO button and turn the keyboard back on. The
screen should display 'Setup is initialising'. This will disappear after a few seconds and the screen will display its default. If that does not work you may need to re-install program disks, I think you should have 6 of them
Sep 30, 2013 | Yamaha PSR-E413 Portable Keyboard
How do I reset factory settings on Yamaha p155
Turn off P155
hold top C key down (furthest white key on your right)
while holding this key down, turn on power,
keep holding key down for 3 seconds, then let go.
should default to grand piano 1 setting
Nov 14, 2012 | Yamaha P-155 Electronic Piano
Rhythm accompaniment does not play. Start button flashes 3 green then 1 red. Began when someone randomly pushed number buttons on the key pad.
Do an initialization (factory reset) by holding the HIGHEST WHITE key down and turning on the power. Hold the key for an extended time until display confirms initialization complete. This will restore unit to factory defaults.
Jul 14, 2011 | Yamaha YPG-625 (YPG625) Digital Piano
How to reset to factory settings
 The initialisation function erases all backup data in the instrument's flash memory and restores the initial default settings. To clear data backed up to the internal flash memory-panel user setting, registrationmemory-turn the power on by pressing the standby/on switch whileholding the highest white key on the keyboard. The backed up data will be erasedand the default values restored.Initialization does not delete the files transferred from the computer.
For further detail see pages 64 and 86 of user manual
Users manual available for download from here
http://download.yamaha.com/search/product/?category_id1=16277&&category_id2=16084&product_id=1056822
Feb 09, 2011 | Yamaha DGX640 Music Keyboard
Yamaha Full-Size Keyboard Logo
109 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
