Kenmore Series 80 heavy duty has a water flow problem
My Kenmore Series 80 heavy duty from abut 1985 has a water flow problem. It started out just being the cold water now it is both. The water just dribbles out. The cold I can get to flow by turning the main water valve off and back on. if the hose is disconnected the water flow is fine, so it has to be in the washer. The fact that if I turn the valve off and back on makes me think it is something other than a clog.
    President:
  • 1,776 Answers
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid and the water inlet valve assy will need replaced. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 06, 2009
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
Water not cutting off at full level and leaking-Kenmore washer 80
The water lever sensor/switch is not working and needs to be replaced. IT has a air tube that senses the water lever by pressure. It the tube is clear then the switch needs replaciing,, If they is a clog, clear it and retry before replacing it.
Feb 06, 2010 | Washing Machines
The hot water was a trickle, so I removed the hot water hose and cleaned the screen filter. I turned it back on and the flow was great for about 5 seconds and now barely flows at all. Worse is that the hot...
Take the hose back off more rust and dirt came through because od the volume of water going throgh the pipe and hose. When you take it off this time run some water at full volume in a bucket to flush everything out.
Reclean the screen and you will be fine...
Heatman101
Jan 21, 2010 | Washing Machines
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
