Curently i using the 2600 fax machine, facing the fax and receiving doc problem...screen will display " NO LOOP CURRENT ". What is the problem ? Previously everything is fine, just happen recently..............
If
the machine receives a fax under one of the following conditions, the
machine will not be able to print the received fax and will
automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
Paper other than A4, Letter, or Legal-sized papers are loaded.
OFF is selected for Auto Print in User Settings.
You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the (-) or (+) button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the (-) or (+) button to select Print all RX docs.
To print the list of documents in the memory, select Print memory list.
To print a specified document, select Print specified doc..
To delete a specified document, select Delete specified doc..
To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the (-) or (+) button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the (-) or (+) button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
The deletion confirmation screen will appear each
time after one document is printed. Repeat the same procedure until all
documents are printed.
The problem is that some one has changed the answering method of the fax machine it writes "F/T" because the fax machine is set to FAX/TEL mode. So to make your fax machine to be on fax mode and on the screen to write " FAX " you need to press the button mode which is located under the screen exactly under the message " F/T " after you will press the button " mode " on the screen it will appear the current mode that the fax machine is set to, so you will need to press the " mode " button until on the screen will appear the message " FAX " when the message " FAX " will appear on the screen do not touch any button on the fax machine and after 2 second on the screen will return to the date and time display and again it will display on your fax machine " FAX " and it will not display " F/T "
A loop current problem indicates that the phone line is not connected to your fax correctly, the cord is broken or where you have plugged into the wall is dead
Place document in top tray adjust guides around doc. making sure the doc. is facing either print up or down according to the machine orientation. Next enter the fax number dialing just as you would a phone and when finished press the START button and off it goes..
all faxes use automatic fallback sytem for dropping the speed as well as the machines communicate on the highest common speed therefor you don't need to set the speed.
Apart from the situation if your phone line is disturbed and not receiving faxes and giving communication errors....
happy faxing
omnipresent
Check the line cable. Try inserting that line to another telephone unit. And if there's still no dial tone the problem is on the line itself. You should call your line provider.
But if the line is ok, check the LIU connectors if it is inserted correctly. It the connectors are ok, then the possible problem is on the tel. line circuit on its mainboard.
