Question about Kenmore Refrigerators
Whats the problem with my ice maker with rattling noise?
  • 304 Answers
Gear stripped in the icemaker head. Replace icemaker assembly.
Posted on Sep 06, 2009
I have samsung french door refrigerator 2 door 2 drawer with vibrating a noise. I have removed the back panel and the noise does not seem to be cominng from this area. any suggestions.
We have a different model Samsung, and I've heard a vibrating or buzzing noise twice. First, if the water filter isn't an exact fit (even Samsung's filters rattle), it will rattle. Second, if either of the ice makers gets stuck or jammed, it can make a vibrating noise. If our freezer drawer isn't making a good seal, ice will build up under the drawer or in the slides. Ours makes more of a humming noise, when this happens. Other areas to check: something stuck in the runner of your drawers or shelves (if yours pull out). There are also vents that draw air in and out of the cooling unit, and things in front of them may vibrate or rattle, too.
Jul 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Dovier ice cream maker- the unchilled cylinder makes a rattling sound- has something gone bad with the chemicals inside? I havent tried to make ice cream recently; it has set for many years without use....
The rattle noise is normal. My Donvier is 20 years old and still works well. I prefer using a large flat spoon to stir the contents by hand (no lid needed) Stirring by hand is easier and more efficient. Just don't touch the frozen cylinder with bare skin.
Jun 14, 2013 | Donvier Ice Cream Maker 1 Quart
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Kitchenaid refrigerator making rattling noise
YOUR ARE GETTING ICE AROUND YOUR FREEZER FAN BLADE THAT IS THE NOISE YOU ARE HEARING IT COMES FOR THE ICE MAKER FILL TUBE THAT COMES IN FROM THE BACK WALL OF FREEZER TO THE ICE MAKE YOU CAN'T DO ANYTHING TO FIX IT JUST MAKE SURE YOU HAVE NO ICE BIULD UP IN THAT TUBE IT MAKES IT LEAK DOWN ON YOUR FAN
Oct 30, 2012 | Refrigerators
Ice maker is making a rattling Josie but when the door opens the noise stops
It sounds like the pump, either a bearing gone or a lump of limescale in it. The noise stops because the pump stops when the ice is made. Try descaling with solution, but be careful to follow the maker's instructions
Apr 11, 2012 | Refrigerators
Waterline Rattling AND DIRTY ICE CUBES
Sound like a clogged valve or a dirty water filter. Change the filter then try it. Good luck.
Nov 09, 2009 | Refrigerators
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Intermittent rattling noise in refrigerator
Do you have an ice maker? That noise could be the ice maker trying unsuccessfully to dump ice, usually caused by a defective heater to loosen the ice cubes prior to dumping them into the container.
Possibly even if your ice maker appears to be functioning normally, it may be attempting to dump ice several times before the ice is actually ejected and if you don't use a lot of ice, you'd never notice it.
Hope this helps.
Jun 27, 2009 | GE Monogram Refrigerator Built-In...
Refrigerators Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
