Question about Creative Labs Sound Blaster Audigy 2 Value Sound Card
I have no sound event when I login in window 2000 and logout even if I assign the wright sound in sound and multimedia
  • mpeloq Sep 06, 2009
    all sounds works fine even in sounds and multimedia
    in control panel.
    I add a sound for the SELECT event and when I select
    any applications the sound work fine,,
    the only problem is when I loggin in window or loggout
    even if I save a new scheme,,no sound work for these 2
    events.
    I have window 2000 with a pci soundblaster sound card Creative version 5.1 for the drivers
    best regards.
    I would appreciate to have a hint.
    I desinstalled and reinstalled all drivers,and there is no change.
    this problem exist since my last update with microsoft
    and I have tied also to delete the latest update,but still exist with the loggin or loggout window for
    the event sound which normally should work.
  • muebe May 11, 2010
    So I gather the only complaint is there is no start up and shut down sound..does all other sounds work? Are you using on board audio or a pci audio card like Audigy?
    Scholar:
  • 36 Answers
Creative Labs is one of the best sound cards ever made but all with the same bladie problem, they do not sign there IRQ values right. It is the address the computer uses to know where the video card or the sound card or the usb ports are. Vista solved this problem.
Hint:
Because the IRQ is the same as one of the other hardware there is a address clash (the same IRQ values).
Easy way to repair this problem is to switch this card to another slot it will change the IRQ adress and your problem should be repaired.
If this did not repair the problem ask someone who knows how to assign IRQ dresses to hardware.
Posted on Sep 06, 2009
  • mrtj30 Sep 07, 2009
    Did you try to restore and use a system restore point before the update this happend to me with my graphics driver and I restored to a previous restore point and it worked finally.
My windows is in spanish,forgot my password help
If you're under Windows XP you can try pressing Ctrl+Alt+Canc twice at the login screen, a Windows will pop up asking you to type in a valid username and password. In the username field type "Administrator" (without quotes), leaving the password blank. If the Administrator account is not disabled and still has the default (blank!) password, the system will continue to load. Then go to the control panel and delete the password for your locked account, logout from the Administrator account and log back in from the account that was locked.
This only works under Windows 2000-XP.
Or consider using Kon-Boot (commercial) or other similar utilities.
Sep 09, 2014 | HP Computers & Internet
Tip
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
Windows logon problem
so it logs you in and then logs you back out immediately? If that's the case try booting in safemode by hitting f8 during boot.
Oct 09, 2012 | HP Compaq 6820s Notebook
Can not open yahoomail
create a new free yahoo mail account open it on your pc and logout. Then login through your old email account and you will be able to login. In case you are unable to login even after that kindly let me know the error message.
Apr 28, 2011 | Yahoo Mail
Why the windows was shut down automatically ?
Some programs after installation will auto reboot the computer but this is not common. One option you have to find out why the computer restarted is to go to Even Viewer and look over the Windows log files. You can do this in windows 7 by clicking on Start then typing event viewer and select "view events".
When the event viewer window comes up you can view your computer log files and possibly find out why it was restarted.
Regards,
G33k
Feb 19, 2011 | Microsoft Windows 7 Ultimate for PC
Can't log on to facebook
Sounds like you need to logout of your husband's account first:
  • go to facebook
  • top right corner, click Account -> Logout
  • now you should be on the login window, use your email and password to login.The top right corner of the window looks like this
Apr 10, 2010 | Facebook Social Network
Hi i let my friend use my computer to check her fb page now whenever i try accessing mine i get hers even when i get a messg sent to me please helpASAP! Thank You
Open the facebook page and click the LogOut link located in the top right corner. Then login using your username and password.
Regards,
nicolasiac
Feb 15, 2010 | Computers & Internet
Windows 98
Just hit the Cancel button and login. Then ask do a search for:
*.pwl
Look for the pwl file that has your username in it. Delete that and logout. Then login to the account you forgot the password for. It won't have a password this time...
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 07, 2008 | Microsoft Windows XP Professional With...
Logitech Microphone Not working
Hi, I have a skype approved logitech headset. I can hear sound, but I cannot record sound or communicate on it. I cannot even find the headset as option as Preffered Device in Sound and Multimedia. I am using Windowsxp
z. Please help.
Feb 21, 2008 | Logitech (980174) Headset
Creative Labs Sound Blaster Audigy 2 Value Sound Card Logo
41 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
