I need to install/update my Canon Pixma iP1700 driver but everytime I run the supposed correct driver/update it constantly fails. This printer worked perfectly on my old printer with Windows XP but I cannot make it work with Windows Vista regardless of how many times I try to download and install the driver even from the Canon and Vista websites. I'm really at a loss on this one.
  • 1 more comment
  • pileduptoher Sep 06, 2009
    Thanks for your help Muebe. This is a whole new computer... I'd give anything to have my XP back. I will uninstall everything I can and try again. I thought I did this befoer but maybe I missed something. This time I'll try to be thorough. Then I'll try it all again. This really is the craziest thing I've ever had to deal with - at least with a supposed "plug and play" type device.
    Ok, you've got me thinking here. I can't remember if I had the printer hooked up or not but I will make sure that is is not this time around. Also, when I bought this new computer it said it the operating sysetem was Windows Vista 64-bit but everything I see when things pop up on the computer and what not says that it is the 32-bit version. Obviously there is a difference, but should I be concerned since it was sold to me as having the 64-bit version?
    President:
  • 566 Answers
Are you downloading the correct driver?
You should install a full driver, not an update, because updates sometimes require that a driver is already installed.
If your system is Vista 32-bit, you should be downloading and installing iP1700 Printer Driver Ver. 2.00 (Windows Vista/XP/2000)
Name of the file: ip1700vst200ej.exe
Version: 2.00
Date: 09/26/2007
Go to to CANON support homepage for your printer:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=13364
Under the "Drivers & Downloads" tab, select your OS and then click the file link under the "Driver" section.
Read and follow the installation instructions in the next page.
Do not connect the printer to the computer prior to installing the printer driver. Do it only if and when the installation process tells you to do so or after it is concluded.
After installing the driver, you can also download and install the software for your printer and OS available from the software section of the downloads page.
For more insformation on how to install the driver and software, make sure you read the FAQS:
8. How do I install the software / driver - Windows?
and especially
9. How do I install using a downloaded driver?
To access this FAQS, click the "Support and Service" tab on CANON support homepage refered to above and then click on the 'Frequently Asked Questions" link.
Posted on Sep 06, 2009
  • A Soveral Sep 06, 2009
    Attention: The driver for Vista 64-bit is different from the one for Vista 32-bit. You must select the right OS to get to the page with the right driver/software for your computer.
    The driver file specifications I mentioned in my prevous post were those of the Vista 32 driver.
    Right click MyComputer icon, click on Properties and check.
    President:
  • 1,015 Answers
Did you do a upgrade to vista from xp? Or is the computer with vista a different computer? The reason why I ask is if you did an upgrade the old drivers and software for xp may still be in the system. The first thing I would do is go into the device manager and remove the printer and un-install any software for the printer. Re-boot the computer and windows vista should detect the new hardware. I would let vista check online for the driver and install it. If it cant't find one the choose the driver you downloaded online. After that then try installing the printer software. Also make sure that when you go to print something that your printer is set up as the default printer.
I have lost my canon pixma iP1700 installation disk and now i want to install it in another computer immediately.How can i do that?
here is where you can download a new driver
http://members.driverguide.com/driver_search.php?q=canon+pixma+iP1700&si=6297f0bd02fddbdbda135293e16ca438&st=1309029540&gqm0=canon+pixma+iP1700
Jun 25, 2011 | Office Equipment & Supplies
THE INK ABSORVER IS FULL
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Step 2 : Using software resetter
  1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
  2. Ekstrak/Unrar/Unzip the Software
  3. run GeneralTool.exe
  4. Select USB Port where the canon ip1300 or canon ip1700 installed.
  5. CLick Lock Release button
  6. Select EEPROM CLEAR
  7. Click Test Pattern 1 button
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
Resetting Ink-Waste Ov
Nov 27, 2010 | Canon PIXMA iP1700 InkJet Photo Printer
Need driver for ip1700 pixma lost the cd donot want to download any driver robot on system
Here's a link to the Canon website page for the Pixma IP1700. Follow the link and down the page 1/4 of the way, you will see Select OS with a dropdown for you to choose your operating system. Once you choose the OS, all of the drivers will appear for download.
Oct 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
No internet access for needed PIXMA IP1700 Canon Printer driver
please you go a autho diler and this printer number give and take install aprogreem driver cd and copy this cd. the next time use
this ok
Sep 14, 2009 | OEM Systems PIXMA iP1800 Photo Printer
Software for pixma iP 1700 printer
http://drivers.softpedia.com/get/PRINTER/CANON/Canon-PIXMA-iP1700-Printer-Driver-195c.shtml here is the site you need
Nov 26, 2008 | Office Equipment & Supplies
INSTALLATION OF CANON IP1700 PRINTER
If you do not have the disk you download software from Internet, follow instructions below,
Click here:Pixma ip1700 Canon Drivers and Software
A web page will open, follow instructions, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthefile,doubleclick on the file, if you get introubles ,thenfollowinstructionsbelowto reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note some printer does not work on Vista.
Sep 23, 2008 | Office Equipment & Supplies
I dont have a cd to install my Canon pixma iP1700 printer. Can u please help me. Thanks
iP1700
Aug 10, 2008 | Canon PIXMA iP1700 InkJet Photo Printer
Printer, Canon Pixma IP 1700
hi Jamal,
you can find out at http://support-asia.canon-asia.com/
for anyone who will try to install CISS on Canon ip1700, ip1300, ip1880 & ip1980
you see more pictures how to install it at http://rapidshare.com/files/210990153/CISS_instalation_Canon_ip1700___ip1980.zip.html
Peace,
Lekker Kontje
Apr 06, 2008 | Office Equipment & Supplies
Free canon ip1700 software
hi sir i need free canon ip1700 software to install my pc plz help me
Feb 16, 2008 | Canon PIXMA iP1600 Printer
256 people viewed this question
k24674
jasbo
jasbo
