Question about Metabo WE14-150 Quick Angle Grinder
Just replaced the brushes on a WE14 150 Quick 6 Grinder and sparks now come from the brushes
  • Anonymous Mar 25, 2014
    how do you replace the brush set
  • 5,660 Answers
From my own experience.
Are the strips of the commutator smooth and flat?
(Not to insult you. The part of the armature that the brushes ride on)
If they aren't, the brushes will bounce up and down.
I put one end of the armature in a drill, and have a helper run the drill. The other end of the armature rests in the front bearing of the grinder head, which is fastened down. (To a bench) Then I use a medium tooth, (B astard) file to dress the commutator bars flat.
I also put medium grade sandpaper in-between the brushes, and the commutator surface to dress an arc on the brushes. (Turn the armature by hand while keeping the sandpaper in place)
Brushes come with a flat surface. Putting a radius on them to fit the arc of the commutator, gives them a good contact surface to start from.
Be sure the springs are putting pressure on the brushes. Sometimes the brush mounts need to be cleaned, or the brush will not slide through the mount like it should. The brush will again, 'Dance' on the commutator. (Bounce up and down)
Posted on Sep 06, 2009
2 Suggested Answers
brewerstool
  • 141 Answers
SOURCE: Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Posted on Sep 15, 2009
Sparks are coming from my metabo w6-115 angle grinder where the bushing are and it seems to be grinding a bit
There are always some sparks with power tools from the brushes.
You should remove the brushes for inspection to check wear.
Be sure to reinstall in the same direction.
Jul 16, 2011 | Metabo 06204 4 1/2" 900W Ang Grinder
I am about to pull out the armature and there is a shield under the cooling fan (which is conected to the armature) that should slide out with the armature. It is real tight and I do not want to pry to...
Yes it should pull out with the armature. The plate can only be removed after you remove the nut and gear on the end of the armature. Make sure your brushes are pulled out first or they can hang up on the bearing at the other end of the armature which may be what is happening in your case.
Jul 11, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
How do you remove and release the quick grinder pad?
There is a button at the front of the grinder usually black or red, depress it lightly and rotate the wheel (unplug grinder please) wait until you feel it fall into spot, depress tightly and hold then turn wheel and unscrew to replace pad. Reverse to reassemble.Good Luck....
Apr 21, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Grinder doesn't start everytime the switch is pushed on and the light at the base of the tool comes on. What could this be ,the grinder is several years old.
that is a service tool light and more than likely the brushes are worn and need to be replaced, make a wiring diagram before removing anything, you can get parts from ereplacementparts.com, you would need your brand and model number. Let me know if you need more assistance
Jan 29, 2011 | Metabo 01451 We14 150 Quick Electronic 6...
Grinder runs about 2 minutes then shuts off. I replaced the heat sensor- no change. What else could be the problem?
check the condition of the brushes, make sure not sticking in the brush tube and also look at the commutator for a really dirty surface.
Dec 21, 2010 | Metabo 01451 We14 150 Quick Electronic 6...
I had been using this grinder for about 2 weeks with no problems. A few days ago while using it it just popped and hasn't worked since.
These are great grinders. I have two of them. One version (more expensive one) has soft start and good overload system. Other version is basic grinder. if it (popped) most likely a short in the motor. Is it possible you got an unusual amount of grinding dust into the grinder? This grinder has a safety feature on the brushes, that keeps from burning up the armature when the brushes wear out. I doubt you've worn out a set of brushes in 2 weeks, unless you've been using it non stop. At least one of the brushes has a small plastic insulating pin inside the carbon. When the brush wears down enough to expose the plastic pin, the spring loaded pops out, lifting the brush from the armature , which opens the circuit. You could remove the brush holders and inspect the brushes. If it is 2 weeks old it is under warranty, and you should return it where you bought it.
Jul 14, 2010 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Carbon brush sizes
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
Just replaced the brushes in a Metabo WE14-150Quick Angle grinder
when you replaced the brushes did you notice the tool throwing sparks? Generally when I work on these after replacing the brushes I have to clean the commutator to seat the new set. You could also have other problems, e.g. bad brush holder (did you replace as assembly or just brush) Let me know what happened to the first set and if when you plug in and try it does it come up to full speed.
Sep 12, 2009 | Metabo WE14-150 Quick Angle Grinder
Metabo WE14-150 Quick Angle Grinder Logo
282 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
