Question about Maytag Washing Machines
I have a 30 year old top load maytag that has a burn smell and did not complete cycle
  • 304 Answers
Likely a burned belt. Tilt machine back and belts are underneath machine. Always replace them as a set. At right front is pump pulley. Turn it by hand to be sure it's not bound up.
Secondly run hand up the inner tub to the top until you find a finger wide space at the top of the tub between the tub and the upper tub cover. Stick your fingers as far into that space as possible and run them 360 degrees all the way around the top of the inner tub. This checks for clothing that may have gone over the top of the tub and gotten caught there. This occurrence and something caught in the pump can burn belts.
Lastly, if the first two tests don't reveal a problem, replace both belts and test the machine again with agitate and spin to see if belt is overheated again. If not, you have fixed problem. If so, you likely have a problem beyond your abilities and the value of the machine.
Good Luck
Posted on Sep 06, 2009
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
Burning smell when my Maytag top load washing machine is running
Sounds like the belt is sliping. ether it's loose, or the trans needs lubed, or both.
Jan 14, 2009 | Maytag SAV5710 Top Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
May 05, 2008 | Maytag Legacy Series Top Load Washer
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing Machines Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
