Question about Nintendo Wii Console
Please help .. my wii remote only works backwards.. cant play i bought a new sensor bar (wireless) still same problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have a new remote but i cannot use it.there are brand new batteries,
Posted on Jan 04, 2010
My wii sensor bar that came with my wii broke. I went to buy another one from walmart, all they had were wireless. I bought the wireless sensor bar but i can't see the cursor anymore to select to play...
You should try and unplug and re-plug everything before anything else. Also ensure your Wii Remote is synced up to the console.
If there are any more issues I suggest returning your wireless sensor bar and getting a wired one. Although it shouldn't really matter if it is wireless or not. Also make sure there is nothing blocking the signal.
May 16, 2011 | Nintendo Wii Console
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
Wii Remote Turning Funtion Doesn't Work on Mario Kart
Your wii sensor bar probably went out, replace it. They sell wireless ones at wal-mart for $20. If you want to make absolute sure that the bar is broken, take a video camera and take a quick video of the wii bar while it's connected and the wii is on. If you see four little blue lights on each side then you're wii bar is ok, if any are gone it should be replaced. The fact that all the buttons are still working means that your wii is still communicating with remote using bluetooth, but since it's not sensing any motion, it probably means that the problem is sensor bar related.
Aug 25, 2009 | Nintendo Wii Console
Wii Remotes not connecting ever!!!
see any obstacles are in the middle of it or radio waves effecting its freqency. or the remote may be damaged
Apr 28, 2009 | Nintendo Wii Console
The wire of the nintendo wii sensor is riped
well that basicle means that you cant play your wii because your wii motes cant register to the wii. wii sensor bars are pretty cheap and if you dont want the hassle of wires everywhere then you can just get a wireless sensor bars that are pretty pricy but not too bad. the downside of a wireless sensor bar is that the connection isnt that great and it drains battery life life CRAZY.
Oct 17, 2008 | Nintendo Wii Console
Wii remote hand not showing up on screen
on the front of the wii theres a red button you have to keep you finger on that for 5 seconds and try again this has to be done everytime u have to sinc a different device.
May 08, 2008 | Nintendo Wii Console
Problem with wiimote
the problem could be uv light, if its daytime make sure all the blinds are closed no extra lights are on near the sensor bar. if there is a glare on the screen at all it could be reflecting light to the wiimote as well. I've had that problem before myself, if that is not the case try moving closer to the sensor bar, make sure the sensor bar is connected correctly and then go to the system settings menu and calibrate the wii sensor bar and adjust the sensitivity, make sure you are not sitting at a wide angle from the snesor bar either, you can tip the sensor bar left and right in order to allow yourself a wider angle. also avoid using the nyko wireless sensor bar, it has a shorter range than the wired one that somes with the wii, mine came with a wireless on(used) and i just got a wired one and now it works much better. well I hope you find this info at least a little useful.
Feb 15, 2008 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Sensor bar / remote issues with Golf games
Has the sensor bar perhaps been moved? Is it becoming obstructed by furniture or something else?
Sep 09, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
190 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
