Question about Nintendo DS Lite Console
The touch screen is not as sensitive as it should be - when I use the ds pen in some spots, particularly on the right side of the touch screen, it doesn't always work...
  • 20 Answers
DS fixing solution = NONE: Your DS is old and should be treated more gently. DSLITE: it has gotten to worn out. turn it off for 5-10 days at dry again.
Posted on Sep 07, 2009
I have Sony DSC-T900 camera which has recently problem with touch screen sensor in the right corner below. Any function button displayed at the tight side in the bottom of screen does not work or...
For the touch screen to work properly, the screen has to be absolutely clean. From the description, it is evident that the issue is confined to one particular corner of the screen, and any button appearing on that part is not responding to touch. This means that the screen is not clean at that portion. Clean the screen using a good quality micro fiber cloth. Make sure that the screen is absolutely clean and try using with a clean finger or stylus (Sony calls it Paint Pen or Touch Pen).
Aug 26, 2010 | Sony Cameras
My touch pad worked fine last night, but now it doesn't! Help!
well, first you should see if it needs charging. Then turn on the ds and touch the little ds on the bottom of the screen. Go to the calibrate or the thing that is on the right side of the person. Try thr test and dont stop it until its over. Try touching the screen again but if that doesnt work call nintendo which the number is in the manual or find it at www.nintendo.com. See if that works.
Dec 27, 2009 | Nintendo DS Lite Console
My ds stylus screen wont worl!
Check all of the below:
Are you using the top screen? The lower screen is touch sensitive, not the top.
Do you have a protective covering on the screen? These sometimes interfere with the sensitivity of the touch screen.
Are you sure it's a ds? That picture is definitely NOT a ds.
Jan 05, 2009 | Nintendo DS Console
Samsung YP-P2 MP3 Touch screen
it is pressure sensitive so, unfortunately, a stylus type pen won't work
it'll only register your fingers
Dec 29, 2008 | Samsung YP-P2 Digital Media Player
G-Pen F610 blind spot (pen won't move over particular section)
Sometimes it is caused by a metal plate coming in contact with the sensor pad inside of the tablet. It is only fixable by dismanteling the tablet and putting an A4 sheet of paper between the back side (the one that has the metal plate which can be the culprit) and the green pad (do not touch it!). This issue usually appears after continuous use when the green sensitivity pad is pushed down a little and is short-circuited by the metal pad on the inner side.
Dec 28, 2008 | Genius G-Pen F610 (31100050100)
Nintendo D.S. screen is "off"
you are in need of a new touch screen. I just bought 10 of them and will replace it for you for $24.
ninja_freak318@hotmail.com
Dec 15, 2008 | Nintendo DS Console
My nintendo ds lite the touch screen does not work
if your touch screen is non responsive I can replace it. I have new touchscreens in stock for $24.
Dec 07, 2008 | Nintendo DS Lite Console
When I use my pen to click on my nintendo DS screen,it touches or selects somewhere else on the screen so I can't play my games properly.
Might need to re-calibrate your screen. From Nintendo's site.
1 Remove all games from the DS.
2 Turn the system on.
3 Press the A Button when the "Touch the Touch Screen to continue" message appears.
4 When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
5 Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
6 Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
* You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
* If the above steps did not help, there is a problem with the system and it will need to be repaired.
7 When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
8 Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
Jul 31, 2008 | Video Game Consoles & Games
Left side of the screen not responding
  • Be sure that you're using only the bottom screen of the Nintendo DS Lite with the stylus. The upper screen is not a touch screen.
  • Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS Lite
  • If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen.
    1. Remove all games from the Nintendo DS.
    2. Turn the system on by pressing the POWER button.
    3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
    4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
    5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
    6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
      • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
      • If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, clean the screen.
      • If the above steps did not help, there is a problem with the system and it will need to be repaired.
    7. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
    8. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
    Jul 14, 2008 | Nintendo DS Lite Console
    Nintendo DS Lite Console Logo
    54 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
