I have spots on clothes at the end of the wash cycle of my Maytag Neptune washer. The spots smear like oil and wash out if the wash cycle is repeated. Is there a bearing or something that couls possibly cause tiny spots to appear on my clothes?
  • Washing Mach... Master
  • 1,606 Answers
Your using a liquid fabric softner . Try using dryer sheets instead , or , a different brand of softner .
Posted on Sep 06, 2009
My clothes are coming out of my Neptune Maytag Washer with little black spots I always dry the washer and have no mold issues that I am aware of. What could be causing these spots?
Hello, unfortunately this was a common problem with that machine , the seal and bearing in the washer tub is worn and the grease is leaking out of the bearing and seal and is getting on your clothes. This is not a cheap repair, in fact I would recommend at this point to purchase a new or even a used washer from a shop that gives you a decent warranty.
Sep 28, 2015 | Maytag Neptune MAH5500B Front Load Washer
Why won't my Maytag Washer extract water properly from clothing after going through the complete cycle?
Belt tension spring faulty, belt loose. Pump partly blocked, look for coin caught in hoses. Internal clutch failed in gearbox, replace gearbox. Gearbox pulley wrongly adjusted, remove pulley, re-grease, re-install with correct clearance.
Dec 18, 2013 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer is spotting my laundry - especially light colored towels with possibly an oil spot - about the size of a dime or sometimes quarter. I tried running a cleaning disc thru it twice ,...
f you use cold water wash and rinses regularly it may have an accumulation of un-dissolved detergent, dirt/grime and body oils stuck on the inside wall of the outer tub. When washing whites I assume that you are using Hot water and it could be causing some of the accumulation to break loose in small clumps and re-depositing on the clothes.
Jan 10, 2011 | Maytag Neptune Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer is leaving dirty spots on clothes
If you use fabric softener it may be from the softener. Dilute your softener 50% before pouring it in.
Sep 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer MAH3000AWW
order the wax motor kit and replace parts from the internet. there are plenty of videos how to do this. it does require minor soldering and a little mechanical aptittude.
Dec 30, 2008 | Maytag Neptune Washer
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
