Question about Microsoft Xbox 360 Console
Xbox 360 my xbox360shuts off whilr i am playing and shows a red light on the left side of the ring and when i check to see if it is hot it is not hot so wht could be the problem
  • fffjjjjjj Dec 27, 2007
    every time i play the thing in the middle of the controller shuttes off and keeps on doing it
  • 79 Answers
I think you could have a problem with your video cable, make sure all connections are secure. Search for 'xbox 360 error codes' in Google, this may help you find another solution..
Please rate if at all useful, thanks!
Posted on Dec 08, 2007
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I am having the infamous Red Ring Of Death issue, ...
Sections 1, and 3 are flashing red
- Overheating
Alternatively Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
1. Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
2. Verify that the console has sufficient ventilation and that the fan is operating.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
* Do not block any ventilation openings on the Xbox 360 console.
* Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
* Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
* Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
May 21, 2010 | Microsoft Xbox 360 Console
I just put a new case on my 360 and it has a clear pece that goes over the dvd drive so you can see the disc when i play for at leat 30 minuites the video cuts out the controoller continues vibrateing and...
left side, means thats your 2 red lights is your AV/HDMI cable not connected properly. 3 red lights is the ring of death. 4 red lights is the disk drive/laser has gone.
Aug 09, 2009 | Microsoft Xbox 360 Console
2 red lights
Your xbox is overheating.
1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. 3. If the two lights continue to flash after trying the above steps, you'll need to contact Xbox Customer Support.
Jul 13, 2009 | Microsoft Xbox 360 Console
Is it possible to fry your xbox 360?
The two red lights is an overheating issue. It correlates with the 3 red lights. First check with Microsoft if your warranty seal is still intact and ask them if its under warranty. also there are some vary qualified technicians who guaranty their work up to 90 days.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
MY XBOX 360
ok, im so sorry to tell you this but i heard that if the ring on your xbox 360 is red its having a meltdown and its totally broken. my friends xbox did that and he had to get a new one
we called it "red ring of death" please tell me does it play games
Jan 16, 2009 | Video Game Consoles & Games
X box 360 stopped working
It happened to me that shows your xbox is faulty .
Sent back to manifacturs. call 08005871102
and follow instructions
Quite simple really.!!
Oct 09, 2008 | Microsoft Xbox 360 Console
360 issues
Two Red Lights
The two left quadrants of the Ring of Light flash red on the front of the Xbox 360 console
This behavior occurs when the internal temperature of the console exceeds the acceptable limits. You may think of this as too hot, overheating, and so on. Make sure the fans are operating and the system has adequate ventilation.
Since you've been inside it's possible that a heatsink or some other part of the cooling system is not working properly or is loose. Check all these!
Good Luck!
Nov 17, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
