Question about Sony XM-2165GTX Car Audio Amplifier
Amp wont stay powered on as soon as bass hits in goes into pm
The amp powers on and i can turn the reciever upto about 20 and then it will immediatley shut off and go into protect mode
    Problem Solver:
  • 11 Answers
The amp is not geting enough current.You need to use some larger gauge cable and it would probably be best to add a small power capacitor.If your not familiar with a cap then stop by your local car audio store or google it and you will get a lot of imfo.
Posted on Sep 06, 2009
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
I have a sony 100 watt amp and it wont stay on for very long
You need more current.Bass notes require more juice and the best way to get more power for bass is to add a power capacitor to your system . They are easy to install and you can get one for less than a hundred dollars that should be enough for your amp and subs.
Sep 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xplod 1000 watt amp not working
you need a amp kit your battery or alltinator isn't powerful enough to handle the wattage you need a juice can it gives yur battery more power
Jun 30, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Bass goes off when i turn up the volume
You need to install a heavier gauge wire to your amp and a capacitor. It works fine at low volumes because there is enough wattage from the battery to power the bass output of the amp but at higher volumes the amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve of wattage for the amp to use so that it does not run out while blasting your tunes.
Jun 02, 2009 | Fusion FEW12PK Car Subwoofer
Hifonics Nemnsis powerin off.
need to charge you batteries up more bass cuts out because not enough power! i have the same issue! 2 amp slow charge is the best way to charge your batteries!
or caps!
Jan 27, 2009 | Hifonics HFR1 Amplifier Accessory - Remote...
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Nov 20, 2008 | Kicker 01C8VR4 Car Subwoofer
Power fluctuations
This is due to a few things, Your amp, the tempurature in the car, the size gauge of wire, and the alternator, When your hittin hard bass and you notice over time it kinda dies out, it means that your sub is losing power cause of the lack of power your battery and alternator produce, If the amp is fairly big then it needs alot of power to keep it at peak performance, I would recommend getting an capacitor that is well suited for your amp, this will give you the constant power you need and the bass will always stay bumpin hard for a significant amount of time, Also the tempurature greatly affects the performance of amps cause the hotter it gets the less power it delivers then possible shut off where then it will cool off for a brief moment then return for only a litle while if still bumping
Sep 16, 2008 | Rockford Fosgate Punch P550.2 150W x 2 Car...
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Kicker ZX 750.1
I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
Apr 12, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
DAB2204
try turning down the volume level on the power amp.
And see if that works.
Dec 27, 2007 | Digital Audio 840 WATTS 2, CHANNEL HIGH...
Sony XM-2165GTX Car Audio Amplifier Logo
140 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
