Question about Abit KD7-G Motherboard
Intel motherboard d865gbf I can not use my ide
I can not use the master and slave ide connectors on the motherboard at the same time it will not detect one or the other at start up
  • 1 more comment
  • baldeagle856 Sep 06, 2009
    WD hard drive and one cd-rw one dvd
    The hard drive is on the master the cd and dvd on the secondary connector. remove on or the other then it will boot up but can not get into windows it will ask for safe mode but i cant get in
  • Keith Paredes
    Keith Paredes May 11, 2010
    What hard drives are you trying to use?
  • 512 Answers
Http://www.pcguide.com/ref/hdd/if/ide/confJumpering-c.html
You must properly jumper your hard drives and if you are using cd or dvd drives in conjunction with other drives, they too must be properly jumpered. You will also need to connect them to the proper connector as IDE cables usually have two drive connectors and one board connector.
Here is a better site for reference:
http://www.pctechguide.com/tutorials/FLDrive_ConnectCDRW.htm
Posted on Sep 06, 2009
  • 53 Answers
Check the jumper settings.. if properly done.. and still not detect the other one.. check the cable
Need to know which is master, slave and cable select
these may vary depending on the make of your hard drive
enable cable select:I:: master or single driveI:::
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Jan 23, 2011 | Computers & Internet
BIOS will not let me change boot sequence of hard drives. It lists both of them (one SATA and one IDE). Trying to recover info off IDE, primary OS is on SATA. How do I get BIOS to let me change sequence?
check the the jumper pins on the back of the HHD, SATA should be set to master & IDE to slave read the top of the HHD first coz some HHD's have master without slave presant.
boot up as normal then go into "computer" & get the data off the IDE drive.
Oct 20, 2010 | Intel D102GGC2 Motherboard
How do i instal as a second player on an intel board
you remove the first dvd or cd rom. in the back where you plug in the cables, search for a diagram of master, slave and cable select pin sets. on both of these roms, there will be one. set one to master and the other to slave. make sure the master is connected to the ide cable plug closest to the motherboard. the slave will be the last one on the IDE cable.
Jun 04, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Slave drive
If you are referring to creating a slave HDD, then it is not necessary - as this model utilizes SATA hard drives, there is no master / slave concept; it is in the order in which you connect the drives to the connectors on the motherboard. If your reference is to the Optical drives with IDE, then connect the slave drive to the middle connector in the IDE (flat ribbon) cable & ensure the jumpers on both the drives are set to Cable select (CS) - this would be at the rear end of the drive. Connect the IDE cable to the motherboard & the BIOS will automatically assign the drive connected to the end as master & the middle as slave.
Mar 16, 2010 | Dell OptiPlex 210L N (210LNDCELMIN) PC...
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
IDE Primary Master/Slave NONE
Hook the two together on the one working IDE connector. Put your hard drive as the first device on the ribbon cable and make it the master using the jumper at the back. Hook the DVD to the second and set it's jumper to slave. Install your OS then try to figure what's up.
Jan 03, 2009 | Abit KD7-G Motherboard
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Newbie query
well first about the cd/dvd. it debends on the connector, if the connector is wide with 40 pins this means its a IDE. so you would connect it with a IDE cable to a ide connector on the motherboard, and by the way there can be two devices on a IDE cable, the other has to be set to master and the other to slave.
See the small 6 pins next to the cable, there you should also see a small plastic jumper with a metal inside, you need to change this jumper so its either on slave or master, only one slave or master can be present so check the other device also.
The cd / dvd may also be a smaller SATA drive and in that case you simply need to plugit into a small exactly same type of connector on the motherboard.
about the front panel
the connector should be like this
simply attach them to the correct slots
Heres a image, note that his is not your motherboard and they might be difrent.
let me know if you need more assistance.
Jun 06, 2008 | Intel D915GUX Motherboard
Motherboard is not seeing the HD
generally its not a good idea to run both ide and sata drive at the same time.
if you are lucky in your bios it will have a emulate sata as pata/ide drives.
turn this on and be sure to select the ide drive with the OS on it as the master drive so it boots first.
also if you are doing this you will also need to change the jumpers on the sata drive as well to make it a slave and not a master otherwise you will have two master drives and it won't boot.
good luck
smeags
Jan 09, 2008 | Intel D865GBF Motherboard
Abit KD7-G Motherboard Logo
57 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
