Question about SanDisk Sansa e200 MP3 Player
Blue screen When i unplug it from the computer it refreshes, but then the screen goes a navy blue color and wont shut off until the batteries run out.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Screen is flickering constantly and goes black after a while
Look for your computer's monitor settings, then adjust its refresh rate.
To modify a refresh rate on Windows, right-click anywhere on the Windows desktop.
Select "Properties," then choose the "Display Properties" tab on the window that appears.
Click the "Settings" option, then select "Advanced" from the window that appears.
Choose the "Monitor" tab, which lets you access a drop-down menu with the options for refresh settings adjustments. As a basic guide, use a setting of at least 75 hertz.
Confirm the change by clicking "Apply." Reboot the PC to ensure the new settings on the screen take effect.
Check your screen if the blinking problem is resolved. If not, try a higher refresh setting. If there is no change on the flickering of the screen, this means the problem is not caused by the screen's refresh rate. If your computer is not running on a battery or surge protector, shut it down to safely transfer the plug to another outlet Hope this helps.
Jan 17, 2013 | Dell Inspiron 1501 PC Notebook
I was working on facebook last night when my screen faded out then at the top of the screen everything started turning an aqua color with minute sized squares similiar to snow and it took over the screen. ...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
May 18, 2010 | HP Pavilion dv9000z Notebook
I unplugged my emachine desktop when i went on vacation and now after repluggging it is dead to the world?
Hello there:
This is fairly common on these e-machines
Normally what happens is that the silver coin sized cmos battery will drain down and when this does by default it shuts it'self completly down untill you replace the battery ill need to be replaced.
Now what you can try first is to unplug the power cord from the computer and open the case and look for the cord that goes from the power supply that connects to the mother board and unplug it now press in the power on button for 1 min and release and if you have a reset switch do the same thing than wait 5 minutes and then reconnect every thing and try the computer again and see if this will get the system going ok if not get the battery changed and also check out the power supply too to make sure that it is running if not than the power supply may be bad but i dont see why it would if it was running just fine before you unplugged the machine ok
Hope all of this is very helpful for you If so please rate this solution for me
Best regards
Michael
(UNITED STATES NAVY RETIRED)
Jan 07, 2010 | Computers & Internet
The screen is stuck on a screensaver and it will not turn off or do anything
It often happens when it doesn't a file is corrupted. If it gets stuck on "Refreshing database", turn it off by holding the power switch until it shuts down, then plug it on a computer and when the sansa logo appears, unplug it. It will skip the datebase refresh and you'll be able to reformat it.
Dec 26, 2009 | SanDisk Sansa Fuze MP3 Player
Digital Power Saving Mode
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Nov 30, 2008 | LG W2252TQ Monitor
Tv turns blue the shuts off.
symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Sep 05, 2008 | Toshiba 51H84 51" Rear Projection...
Tv screen goes off until you unplug and replug in
That's a video card error. Pulling the plug resets the card, but a firmware or chip problem is reoccurring. It needs a professional service call.
Sep 04, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Royal blue / navy blue on the screen prints out looking purple
ahem...well..this has a lot to do with the rgb to cmyk issues on the transforms. You may need to see if the Photosmart is compatible with the Adobe Photoshop C2 transforms..
Feb 12, 2008 | HP PhotoSmart 7760 InkJet Printer
Black screen blue light
jst leave the batt to die off. then plug in the usb. thats it
Dec 08, 2007 | SanDisk Sansa e200 MP3 Player
Wont start!!
This will take care of it.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
