Question about Pantech C150 Cellular Phone
I can call but I can't receive calls, it goes straight to voice mail. Already changed the forwarding settings and I dont know what it could be.
How do I get voicemail of a Samsung s6 phone .
Samsung Galaxy S6: How to get voicemail (phone calls go direct to voicemail)
Hello.. 2 things we need to address here:
1. How to access voice mail account:
Access VM: Press 1:
Easy way to access your voice message system is to go to the dialer pad on your phone and press down on the "1" key until your voice messaging system announces
or you can dial your phone number to get to your voice mail
2. Change Call Setting, go to:
Dialer > (3 dots) Select Settings > Call > (scroll down) Select More Settings > Call Forwarding > Voice Call > then change to Always Forward (turn off)
Feb 14, 2016 | Samsung Galaxy S6 Edge
Phone does not ring. calls go to voice mail. how can I change this
go to settings call settings click more setting then click call forwarding.click voice call. click disable on all the four always forward , etc and you should be able to receive calls
May 24, 2015 | Samsung Galaxy Note 4G
My iphone 4 goes straight to voice mail on the first ring how can i change the setting
make sure you do not have the settings set to block mode, people often confuse block mode as being the setting that blocks other devices from piggy backing on their wifi. it actually blocks calls. check the top of the phone for the symbols or icons, if you see one that you dont' understand open settings. and make changes.
Aug 21, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Hi. I can't receive any incoming calls, it goes straight to voice mail. But I don't receive a message for missed calls. Help please.Donna
Check with the carrier to see if you have Forward All Calls enabled. There might also be an option on the phone for this
Aug 09, 2013 | Huawei Ideos X5
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
I want to change my voice mail and whenever someone tries to call me it goes straight to voice mail what can i do about this?ive got samsung c3050
The scenario that you describe is typically caused by voicemail service on the carrier's side of the network. The majority of the time, a call being routed directly to voicemail is due to the phone not being 100% recognized on the network (perhaps this is a phone that is replacing a phone on existing account / number?) or roaming is not supported. Some forwarding modes may contribute, but not usually direct to voicemail unless you have inadvertently forwarded to voicemail explicitly.
Jun 22, 2010 | Samsung C3050 Cell Phone
My Avaya phone on our Avaya system only rings
ask your local admin to remove your phone from coverage path
Apr 15, 2010 | Linksys SPA941 IP Phone
INCOMING CALLS
Hi there, it is possible that you have the G1 set into "always Forward" state, which means when receiving calls the phone will forward the caller to your voicemail.
To Check and change these settings. goto the G1's Home screen, Click the "Menu" button, and then click on "Call settings". Then from here click on "Call Forwarding".
From here, the top setting should say "Always Forward" If this is set to Enabled, click on it and select Disable. This should now allow you to receive calls correctly ! if the Always forward function was disabled already, i would suggest calling T-Mobiles Customer support line to see if they have a remedy to this situation !
Hope this helps ?!
Oct 27, 2008 | HTC G1
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
INCOMING CALLS
upgrade the phone to WM6 with A3.5 @ ppcgeeks.com --> apache forums.
that will upgrade the phone's firmware at the same time as upgrading the ROM to WM6
Aug 02, 2007 | Audiovox PPC 6700
Pantech C150 Cellular Phone Logo
198 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
