Pixma cannon ip4000 error reading 5700 trying to take the chasis
I am getting an error reading of 5700 but am not sure how to fix this. I thought it was the cam sensor but cant figure out how to take off the chasis and what this exactly is
Hej I get an error code 6800 Regards Ivan
Service error 6800 means that a problem occurred in reading from or writing to the EEPROM. To fix this you need to replace the logic board. For replacement you can try http://www.partsalliance.com or http://www.ppsnj.com
Mar 20, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Cannon pixma 1500 printer stopped printing color ink is full
Print a test pattern print first to make sure that the problems is the printer and not the file you are trying to print , then check you color cartridge if it's empty.
Aug 17, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I HAVE ERORR CODE 5700 ON MY CANNON MX700 , HOW TO FIX IT
5700 is a sheet feeder error, if there is not something caught inside like a ink pen, paper clip, or kids toy, you might need a new feed assembly. Not too expensive, but a shop repair only.
Aug 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
IP4000 service error 6B00
6B00 is a paper feed error, look in the back with a mirror and flashlight, and see if something has fallen in where you put the paper for printing.
Jul 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Cannon PIXMA Service Error
Hi You can Try 2 things.
Have a go
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 25, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon IP4000 Error Code 5100
It is a carriage error.
Most times this is a serious error that requires a Canon tech to fix it.
Look at the carriage and see if there is something obstructing it's movement. If you recently had a paper jam, there may be some paper stuck in the path.
You should be able to move the carriage freely with the power off.
Let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
see if that helps
Robert
Please rate this solution thanks
Aug 26, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
246 people viewed this question
jasbo
jasbo
