JVC Television timer light flashes and tv won't operate.
  • 8,457 Answers
Ur high voltage is dead.The FBT,call the Fly back Transformer it dead.The plastic block with a red wire to the CRT(ur tv tube) with a cap to it.
Posted on Sep 06, 2009
Testimonial: "Thanks 4 ur reply, yes this is probably the cause of problem. Previous symptoms include picture suddenly disappearing to thin white horizontal line. "
4 Suggested Answers
SkinWill
  • 148 Answers
SOURCE: JVC AV-32260 timer led flashes
When your set first turns on it runs a systems check to see if the boards inside are safe to apply voltage to. also it checks the power supply to see if it is safe to power up.
Either it needs a factory reset which the procedure changes for each model. or it simply has more wrong with it after the surge and requires more to fix it then the cost of a new set.
The best bet is to look on EBAY for a similar set with something like a broken screen. swap out your screen into its chassis.
if you do not feel up to the challenge of doing that you may be looking at repair costs and parts that are more then a new set.
Posted on May 01, 2008
  • 142 Answers
SOURCE: jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Posted on Sep 30, 2008
SOURCE: Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Posted on Oct 04, 2009
Power timer light flashing, won't come on
Flashing of power LED are fault indications. You have to count the number of flashes occurs at one time. Check this link for more details about the blinking codes. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name first.
Dec 22, 2012 | JVC AV-32D305 32" TV
I have a JVC AV 32432 and the on timer light is flashing and tv won't turn on.
Flashing of timer is fault indications. Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 02, 2012 | JVC AV-32432 32" TV
My tv won't turn on and the on timer red light is
depends on brand and model number of set.
Apr 29, 2012 | JVC Televison & Video
My TV a older JVC won't turn on and the on timer light is flashing. I have had this set for many years I have never had this issue
This type of fault is associated with the power panel board, you have to open the back cover of the television to check where the fault is,also take caution because it contain high voltages,the power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will helpout in solving the problem....
May 14, 2011 | JVC Televison & Video
Tv won't come on
check the relay drive transistor
you need a qualified tv repair personal to check tv
Jan 15, 2009 | JVC AV-32D305 32" TV
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC 27" D series
there is another problem that requires a tv repairmans expertise when the timer light flashes continuosly ,and the power is not restored.
Apr 21, 2008 | JVC AV-27D502 27" TV
Television want turn on
In a large number of failures with these symptoms it's usually the HOT (horiz. output trans. Q522, which is a 2sd2499) and the regulator (Str30134), together with fuse F902 (Gma 1.25a). Not an expensive repair or that complicated if you're fairly good with electronics and know how to solder correctly. Otherwise take it in and have it repaired professionally - it's worth it...
Bill
Nov 15, 2007 | JVC AV-27230 27" TV
Jan 12, 2007 | JVC AV-32FA44 32" TV
Televison & Video Logo
222 people viewed this question
Top Televison & Video Experts
