Question about Epson Stylus R380 InkJet Photo Printer
I am having the same problem as them.
I will be printing and the paper goes in and then it jams. The red light comes on and I have to delete the job.
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Posted on Apr 23, 2006
websnail
  • 419 Answers
SOURCE: Both ink and paper feed lights flash red. No paper is jammed.
Two possible causes..
1. If the ink and paper lights are flashing alternately with each other (ie: not together) then it's the old "Service required" problem and a quick visit to wasteink.co.uk will help with that.
2. The cleaning station/wiper (otherwise known as the parking pad) has managed to pull itself out of position and is currently doing an impression of a jack in the box instead of being hooked into the rest of the cleaning/parking system.
If it's the latter you need to move the printhead out of the way (to the left) and then push the white cleaning part down and then across to the right so that it couples up with the black part of the parking pad properly... It's very difficult to explain how this looks but if I get a chance tomorrow I'll put some pictures up on wasteink.co.uk with some troubleshooting info.
That said, you'll probably figure it out for yourself and it's just a bit of trial and error until you get the pad hooked up properly...
Oh and once it's happened once it'll happen again so in my case I put a small dab of hot melt glue on the connection point between the white and black part (once it was back in position) and this has resolved the problem for me.... Your mileage may vary however.
Hope the above helps anyway...
Martin
Posted on Jul 29, 2010
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
How to stop printing once it has started
For Brother Laser Machines. Start by pulling the paper tray out a little. This allows the page that is currently feeding through the system the chance to get through without jamming causing a whole slew of other problems.
Once the printer has stopped trying to feed the pages through coming up with an error saying paper out then you can look at deleting all the print jobs in the print queue on your computer. All but the one currently being printed should disappear when you delete them. The one that is left will be errored.
Then turn your printer off for 30 seconds closing the paper tray and try to delete that last job from the queue.
If it will not go then turn your printer back on and let the last couple of pages print out. these are pages that are stuck in the system. If the print job did disappear then just turn on your printer as normal and it should be clear of any jammed printing and you don't end up with Paper Jams in the printer to clear.
Sep 06, 2014 | Brother HL Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Flashing red error light
It could be a paper jam, clear paper from printer by opening the door and carefully remove paper
Delete print job and restart printer
Mar 22, 2011 | Office Equipment & Supplies
When the start button is pushed the green light come on and the ink cartridge traverses the machine from right to left and then back to the starting position. the green light goes out and the red light...
Hi there try to power off printer then power back on, this is usually a print job that is qued up but not printing, also if you have any print jobs in your windows printer que, delete them with the printer off. this will clear the printer. otherwise check for a paper jamb.
Also try
Hello there Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 12, 2010 | HP DeskJet 845c Printer
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the light turns green. however, when i print a file, the file goes into the print queue for a few seconds then...
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Nov 25, 2009 | Brother HL-5240 Laser Printer
When printing cd's I get: paper jam and red light and reset tray
re-download the drivers for the printing program that you are using for the job, that should fix this for you. good luck!
Mar 06, 2009 | Epson Stylus Photo R220 InkJet Printer
Flashing red lights and letter E on my hp printer
basically for this printer I have found that just restarting your computer will solve almost anything. make sure there is no paper left jammed in the printer and restart. sometimes you have to delete the print job in the printer que. there should be a printer icon down my your clock, right click, open active printers, and delete your file. restart your computer and try again
Sep 18, 2008 | HP DeskJet F380 All-In-One Printer
Print head jam
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Epson Stylus R380 InkJet Photo Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
