Question about Canon PowerShot SD1000 Digital Camera
Lens error restart camera error
I have had my camera for less than a year and barely used...today I was taking pictures and reviewing them when all of a sudden the camera shut off and would not turn on. The "lens error restart camera" message appeared on the screen. It seems as though this is a problem that most people have and canon should recall all powershot cameras and have this fixed.
  • 10,515 Answers
I agree but there is nothing a consumer can do :(
The best solution you can try would be :-
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. It would be better to get it repaired by Canon service center. Also, it should be free of cost if under warranty.
Thanks.
Posted on Sep 06, 2009
I have a powershot sx110 is and while using it today it was fine until ai tried it again and it displayed the error, "lens error, restart camera". It won't restart though. Help!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 31, 2010 | Canon PowerShot SX110 IS Digital Camera
My camera wont take pictures. It will only turn on to let me view the pictures in the memory card. When I press the power on button, the lens comes out just barely, not all the way.
Sep 26, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
The lens will not retract. A message says "lens error, restart camera," but the camera will not restart. The camera is a Canon PowerShot S3 IS. I can hear a "whirring" or motor noise when I try to start...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some simple things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 17, 2010 | Canon PowerShot S2 IS Digital Camera
Screen stays black when turned on in take picture/video mode
There is something wrong with the lens. Perhaps its obstructed by something or the lens doesn't really open @ all. Try cleaning the lens with lint free cloth if not. Follow the in-warranty repair process @ www.kodak.com/go/stepbystep the website will ask you to troubleshoot first. Just keep following the website in the end if issue persist it will give you the page that you need to fill up so that you can send your camera and repair.
Note: After filling-up the information on the page and completing it wait for an e-mail from Kodak it will give you details how to send your camera for repair. It will also contain the address and phone number of the repair centre.
Lester
Kodak technical support
Oct 04, 2009 | Kodak EasyShare C913 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Jan 23, 2009 | Canon PowerShot SD1000 Digital Camera
Lens error!!!!
when i turn on my camera the lens comes out ,then goes back in saying theres a lens error.it tells me to restart my camera but im not sure how too. is it just turning it back on ,or is there a reset button?
Jul 03, 2008 | Canon PowerShot S5 IS Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
125 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
