Problem for Whirlpool Duet GHW9150P Front Load Washer
Duet sport with an error code
Same Problem
Mar 27, 2009
-   F21 error code on whirlpool Duet is solved by reading the submitted solutions. Thank you for all your input.-   Guest Mar 17, 2009
-   Thanks die tryin 45. LOad of towels and company and your diagnoses saved the evening. Thanks so much. 60 cents half a pencil and a hair pin and a pair of tweezers. Who'ld a thunk it. Thanks again
pei guy Feb 22, 2009
-   I have F-21 and have tried everything here. I visually verified the pump is running (ran it with the white plug out and can see the impeller moving). I cleaned lint from the hose coming from the basket to the pump (minor) and removed and checked the outlet hose and it is clean.
I took off the water level switch and blew into the nozzle, verified the click. I blew into the black tube that connects to the switch and could hear air coming out the bottom. Reassembled everything and still got F21. Ran diagnostics (per the secret repair manual hidden behind the bottom panel) and it fails on Rinse/Spin with F21.
I have ordered a new water level switch to see if that is the problem but if that doesn't work, what else can I try?
Lensman6 Jan 24, 2009
-   Thanks for the solution "dye
tryn 45" - worked perfectly.
mayoman Jan 19, 2009
-   Seems like this is a manufacturer's defect - My machine is 14 mos old and is now having the same problem. Thanks for the tips...-
Tmarroccel
Best Solution
posted on Apr 28, 2008
Rank: Apprentice
Rating: 98%, 46 votes
I have a Whirlpool Duet and the washed load would stop and give me a F-21 error. I tipped the washer back a little and removed the three screws on the front bottom cover. There is a large white drain value, turn and open the drain (make sure you have a pan or something to catch the water and any junk inside) to remove the water. Attached to the drain is a black hose with an expanded section, squeeze this to find any loose socks, under clothes etc. I acually found three socks, a battery, a pair of tweezers and a few coins. This F-21 error is a drainage problem, don't call the repair center and pay for a serviceman, it is easy to fix yourself. I hope this helps!!
Was this helpful?33 people thought this was helpful
Solution #2
posted on May 16, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
I had the same problem, error F-21. Unplugged from electric, removed the 3 screws from the bottom front cover, and slid the cover off. Use a large pan or a bucket and some towels to catch all the water....unscrew the white plug and catch the water with the pan or bucket....there will be quite a bit of water! Found a fabric softener, a bunch of lint, and a couple of coins in there. Something that I thought was kind of funny....when you take the bottom front cover off, there is a SERVICE MANUAL in a bag attached to the backside of the bottom cover which explains what all of the error codes mean.
Solution #3
posted on Feb 02, 2008
Rank: Apprentice
Rating: 92%, 8 votes
I have the Whirlpool HE 5T and it has been giving me the F21 code for about a week. I took the back off and removed the Black drain hose from the bottom of the washer. I found a pair of panties stuck in there that was not allowing the washer to drain. If you are having the same problem it might be worth it to take a look.
Tony
Was this helpful?2 people thought this was helpful
Solution #4
posted on Jan 20, 2009
Rank: Apprentice
Rating: 100%, 1 votes
I solved my F21 problem above, figured I'd follow up in case it helps someone else.
After paying a guy $120 to come out and do nothing for an hour, I took a guess and figured the water pressure level switch was not working, which would explain why the machine thought it still had water when it didn't.
Sure enough, I took the switch out, looked it over and realized it was mechanical switches tripped by air pressure, blew a few times into the nozzle where the hose connects, reinstalled it, and it worked. When I blew, I heard a "click" telling me I was flipping the mechanic switch inside.
FYI the part is here:
http://www.appliancepartspros.com/partsearch/frame_partlist.aspx?part_id=3128700&&model_id=5136839&diagram_id=1307753
And the nozzle I blew into is facing right in the photos.
I performed this "fix" long ago and the problem has never reappeared (knock on wood).
Good luck!!
Was this helpful?1 person thought this was helpful
Solution #5
Rank: Apprentice
I work on these machines, make sure you are using the recommended HE detergent, they say 2 tbls or 1/4 cup is what you need. HE stands for high efficiency and it doesnt sud up as much as the regular detergent. Alot of the time when you have too much suds in the washer that error code will appear its very common, see if that helps.
Solution #6
posted on Nov 17, 2008
Rank: Apprentice
We had the same problem! Unscrewed the front cover, drained A LOT of H2O into a big bucket and cleaned out much lint and random metal things. It works great! Best of all I got to call my husband at work and tell him I fixed the washer. WE don't have to [pay anyone to fix it. Thanks!!!
Solution #7
posted on Jul 21, 2008
Rank: Apprentice
Thanks for the info. Our washer displayed the same F21 error code. Unplugged the washer; unscrewed the 3 - 1/4in machine screws with a deep 1/4in socket; removed the bottom panel; unscrewed the white plug from the sump (thanks for the tip on catching the water). Found 2 socks, coins, paper clip, and a button. Now I know where those missing socks went.
Solution #8
posted on Jun 05, 2008
Rank: Apprentice
Yep - drain the hose and it works fine!
Solution #9
posted on Jan 30, 2010
Rank: Apprentice
Rating: 0%, 0 votes
Thanks all for information. Had the F-21 error code and it turned out to be ice in the filter. We had just moved the washer back inside out of storage...
took off front panel, opened drain, and sure enough found ice blocking the drain pump.
Solution #10
posted on Jan 07, 2010
Rank: Apprentice
Rating: 0%, 0 votes
Ok we just did this to our washer and I found a box cutter, two house keys, money, hooks for the christmas and let not forget about the socks. The smell is really nasty.
Solution #11
posted on May 12, 2009
Rank: Apprentice
Rating: 0%, 0 votes
read below, they are all right (except the manufacturer defect one, unless the whirlpool people snuck in my house and put my undies in the drain filter) Thanks everyone...and I made 42cents!!!! BONUS
Popular Solutions for Whirlpool Duet GHW9150P Front
1 Solution
1 Solution
1 Solution
1 Solution
Questions and Unsolved Problems for Whirlpool Duet GHW9150P Front
Do you recommend Whirlpool Duet GHW9150P Front Load Washer?
washer will not start. beeps three times, then nothing. I just washed one load and then tried the...
(More)
washer will not start. beeps three times, then nothing. I just washed one load and then tried the second and i won't go. it is a whirlpool duet.
rug will not spin, full of water
I have a Whirlpool Duet washer and it displays the code F2 between rinse and spin. It sometimes has...
(More)
I have a Whirlpool Duet washer and it displays the code F2 between rinse and spin. It sometimes has the words Suds even when I do not put any detergent in with the clothes.
just after starting washer the numbers on the display starts flashing and washer quits. you cannot...
(More)
just after starting washer the numbers on the display starts flashing and washer quits. you cannot cancel or anything. the only way to get the door open or reset is to unplug. sometimes i recieve an f-06 code.
i have a duet washer between wash and rinse cycles it stops code comes up f2 and sometimes sud now...
(More)
i have a duet washer between wash and rinse cycles it stops code comes up f2 and sometimes sud now it doesnt drain
10 Other Users Have The Same Problem - Continued
Comment by n_botm, posted on Jan 17, 2009
Response by "die tryin 45" was useful, and solved the problem , however this is the third time I have had to unclog the drain valve, and this time it was clogged with a sock and a wash cloth. It's nice to know I can fix the problem in the short term myself, but it certainly seems like a design flaw if a sock and a wash cloth can clog the drain
Comment by die_tryin_45, posted on Dec 28, 2008
I had the same F21 fault code as well......pull the front bottom cover off. ( 3 1/4 inch machine screws.) There will be a big white drain valve on the bottom right of the washer. Open this valve open slowly with something under it catching all the water. I slowly opened it not unscrewing all the way ( took 3 pan fulls.) to empty. I personally found .63 cents, a nail, a ink pen, 2 dryer sheets, and lots of dog hair. Kinda gross job but well worth not paying a mechanic to come out!! Job in total took only about half hour. Thanks
Comment by buzzben, posted on Feb 01, 2008
Same problem, F21. Tried replacing the pump, didn't help. Had a repair guy out and he dumped 2 gallons of water in the empty tub, ran a drain cylcle, and it worked. 3 loads later, F21 is back.
Of course my unit is 25 months old, just past the 24 month warranty. I wonder if there is a time bomb in the electronics. ;-)
Comment by Guest, posted on Dec 26, 2007
I have had my Whirlpool Duet for a year and the F21 code flashes and stops every load of clothing. The code says that their is a problem with drainage. We even invested in digging up 100 yards of drainage in the yard and replacing it thinking that maybe something was wrong. IT DRIVES US CRAZY!!! I wish I had never purchased this set. Does anyone know how to make it STOP!!! I would love to do ONE load of clothes without it stopping.
Comment by 1hurst, posted on Dec 12, 2007
Whirlpool Duet Sport washer stops and flashes F-21.Whats the problem and how do i fix it?
