Question about Water Pik Health & Beauty
Sticking water release button - Water Pik Health & Beauty
Sticky shift release button
Fallow the video and then soak it in water with dawn dish soap.
Jul 26, 2015 | 1998 Chevrolet Malibu
Tip
How to release the stuck steam button in Shark iron-61468-10?
If the steam button is got stuck in the down position in your iron then follow this procedures to release the stuck button:--
1) First of all pull the button up. You may have to coax it up; you can pry it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only).
2) Below the button is a stem that operates the valve, gently pull it back up with a pair of needle nose pliers (careful - the stem is made up of plastic material).
3) Then replace the button (align the stem into the hole on the bottom of the button to its exact position. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :)
It seems like it sticks when the iron is left unused condition for a period of time; as if the valve gets stuck up when dry. leave water in it this time, although the instruction manual says not to. But leaving the water in it may not let it get dry.
This will help.good luck.
on Feb 28, 2010 | Irons
Spitting sputtering
Your water solenoid is sticking. It is drawing air back through it when off then the pressure of the water is keeping it open. I would replace the solenoid valve.
Apr 14, 2014 | Amana Refrigerators
Back seat belt release button sticking
You will need to remove the seat cover and free up the linkage of the release button.
Jun 12, 2012 | Cars & Trucks
Water button sticking
Replace that microswitch for the dispenser lever. It might not be a separate switch though, it may be part of the control board for the dispenser module. disconnect power to the fridge, remove the dispenser cover to expose the wiring, etc., determine what the lever actuates when depressed, and it will likely be the microswitch separate from the board.
Jul 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
2000 cadillac gas lid and trunk will not open when you push on the button on the dash.
they do have a fuse you can check! however in cold weather its common for the release cables to stick not! allowing then to pull the release triggers back far enough spray some deicer in the lid areas or use hot water around them and then try to open
Jan 22, 2010 | 1998 Cadillac DeVille
Gear stick stuck!
Are you pressing down on the brake padle when you are trying to get it out of park? If that don't work check the fuses & there may be a relay that's may be related to a safty divice to the stick shift. If you don't press the brake padle the stick shift will not release so if you leave the car running a child could not push in gear. The lock silinoid is at the gear console
Apr 24, 2009 | 1993 Volvo 240
Water dispenser conditnues to drip after releasing the button
No seal or gasket on the water line... you do have a water valve that maybe sticking open .... and/or the switch in the water dispenser is stayng open...hope it helps let me know..
Jul 22, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Taking still photoes with the memory stick.
1. Set the mode switch to MEMORY STICK. 2. Set the power switch to CAMERA. 3. Press the PHOTO button and hold it. **If you do not wish to keep the still photo, wait 2 seconds until the picture releases. 4. To keep the image, pess the PHOTO button once again within 2 seconds after releasing the button. The still image is recorded to the Memory Stick. **Audio cannot be recorded onto the Memory Stick.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Health & Beauty Logo
152 people viewed this question
Top Water Pik Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Water Pik Health and Beauty Expert? Answer questions, earn points and help others
