Question about Olevia LT37HVS 37 in. LCD HDTV
My Olevia LT237 37"HDTV shuts off while watching.
While watching tv it just shuts off, the blue light does not come on. I press the remote and then the blue light comes on, the I restart the tv, at this point it comes on again, after watching for a few minutes it does it over and over again. I can not watch my tv, it is only one and a half years old. Picture is perfect "when and if it works". HELP
I was having the same issue. It was driving me crazy. At one point I went over to the tv and I put my hand on the top. The amount of heat coming out was unbelievable. I know that I am only prolonging the inevitable and I do not recommend this as a permanent solution. However, I have found that if you point a fan right at the side of the tv to keep it cool, the problem seems to go away. I'm sure that the other solution posted above is probably a better one. But it will get you by until you get the tv to the repairman. . .
Posted on Jan 16, 2013
  • 92 Answers
Take the TV to a local repairer, it sounds as though as it is warming up some components on the Power Supply are failing.
A fairly common fault, not too expensive to fix.
Perhaps $80 if it can be repaired, $150 to replace the PSU.
Posted on Sep 06, 2009
Tv won't turn on no blue light either
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Olevia LT23HVX 23 in. LCD Television
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Olevia TV shut off by itself.
You probably have either loose solder joints or components that failed after heats up. You need to look inside to see. Learn more about failed TV and monitors, caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Televison & Video
Would like to use Direct TV remote instead of Olevia remote
Try the following steps:
1. Turn on the tv. 2. Slide the "Mode" switch to the "tv" position 3. Press and hold the "mute" and "select" keys at the same time until the green light under "tv" flashes twice. Release both keys. 4. Using the remote's keypad, enter the digits 9-9-1-1 5. Press "pwr" key. Point the remote at the tv. 6. Repeatedly press "channel up" key until the tv turns off. 7. As soon as the tv shuts off, press and release the "select" key Your remote should now be programed to the tv.
All of this information came from the link below. If you have any more questions, this link may be able to answer them for you:
www.directv.com/learn/pdf/Remote_Controls/DIRECTVRC64forWeb.pdf
Thanks for the question, and good luck! Sincerely, Der Strom
Apr 12, 2010 | Olevia LT37HVS 37 in. LCD HDTV
I have two remotes. One is for the Olevia TV and one is for the cable - Smart City. I only use the Olevia TV remote for powering on and off and volumn. The channel down button on the TV remote got...
Make sure your cable box is on and on a channel that you normally watch so that we know there is video being transmitted to the TV,then useing the remote that came with the TV press the button that is labeled " input" or " source" multiple times until you see a picture back on your TV screen. Good luck and Happy Holidays!
Dec 23, 2009 | Televison & Video
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
TV can't be turned on
I would check the capacitors on the power inverter most problems with LCDs can be attributed to that or the backlight
May 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Olevia LT37HVS 37 in. LCD HDTV Logo
296 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
