Question about Universal Remote Control MX-3000 LCD Touchscreen Remote Control
My mx 3000 will not charge. I got a new battery & nowthat is dead
I think the charger base is not working
    Problem Solver:
  • 15 Answers
Contact Total Control Remotes - www.totalcontrolremotes.com - They offer diagnostics over the phone and in the least can get you a replacement battery or base in a day or two. Great customer service and many different types of products and services.
Good Luck
Posted on Sep 27, 2009
Red light indicating fone charging has not shut off for around 20 hours.
My Vtech 6.0 charging light only turns off when I remove a handset from the charger base. I have had these three set for two years and they work fine. I think that the red light is just to let you know that the charger is working, if you loose power, or unplug one of the base units there is no indication of a dead battery.
Jun 11, 2011 | Vtech Cordless 6041 Phone
Will not turn on
Thank you for your question.
This camera has no low battery indicator light. It also has a short battery lifespan. You may want to buy a new battery, charge it up and try it.
Here's where you can find the battery:
http://www.thediscountplanet.com/Store/search_results.asp?v_search=powershot&v_type=0&v_supplier=0&page=1&lowest=0&highest=9999999&map=0
If this does not solve the problem, check that your charger is working. If chargers go bad, the user thinks they charged the battery all night and the camera still doesn't work.
Many times, the battery goes completely dead because it hasn't been charged in months. In this case a new battery and charger may be purchased to solve the problem.
Feb 22, 2011 | Canon PowerShot SD1000 Digital Camera
Mx3000 does not charge when in cradle. nothing
I agree with ceocass, however if you find that the contacts are clean and you have made certain that the charging cradle is plugged in you may simply need to replace the battery.
Please note that the replacement batteries for the MX3000 Universal Remote Control, p/n's Powercard PC046067-H & PC036067V3 have been discontinued.
TheBatteryStore.com now carries an alternative battery, p/n PL056067V3 which is a 2,100 mAh typical capacity battery that can be used as a replacement.
Please confirm that the connector type is the same as your battery prior to placing your order. We only carry this battery with the Version 3 connector which has a built in pressure release tab.
The link for the product page is: http://www.thebatterystore.com/replacementbatteryforuniversalremotemx-300037v2100mahli-ionpolymerrechargeable.aspx
If you have any questions please contact TheBatteryStore.com at sales@thebatterystore.com.
May 27, 2010 | Universal Remote Control MX-3000 LCD...
I think my battery is dead. Do I try to charge it
To charge battery, use a trickle charger at 2 amp. Batteries usually only last about 3 years, so if battery is at that age it probably needs replaced. (Replaced my battery with a lawn mower battery that matched the original battery size.) I would try to get a charge on the battery before replacing it. Replacing the battery could be expensive. Battery could also be low on zinc, water, or acid.
May 22, 2010 | 2004 Yamaha V Star Custom
Where can i purchase a battery pc 046067h for my MX-3000 remote in the Denver metro area ? my current battery needs to be charged daily....think its out of gas.
Amazon.com sells them. MX-3000 replacement battery @ Amazon Should be a pretty simple replacement, possibly a few screws on the back, use care when removing the old battery, as sometimes these connectors can cause damage from bending the pcboard it is attached to, same with installing the new battery. Don't be afraid of it, just treat it like a lady and it'll make you breakfast. Well, probably not. Good luck!
Thanks for using FixYa!
Dec 04, 2009 | Universal Remote Control MX-3000 LCD...
Power Card will not hold charge cannot find replacement
the battery may be faulty or the charger. try a different charger and see what happens. one of them is the problem good luck.
Aug 18, 2009 | Universal Remote Control MX-3000 LCD...
MY MX 700 OPTICAL MOUSE WONT CHARGE I PLACED IT ON THE CHARGER AND THE RED LIGHT JUST FLASHES IT HAS NEW BATTERIES AND A GOOD CONECTION WHAT DO I DO I have an MX Laser (old but outstanding!) that will not...
Hi smeker2003,
I have the same mouse and the same problem, it has been getting worse for some time. The reason they do this is the gold foil you see on the contacts corrodes away and eventually looses the ability to conduct enough electricity to charge the unit.
If yours is in the beginning stages of failing, simply cleaning the contacts and repositioning it slightly in the charging base may get it charging for now but it won't last long. Mine started having minor troubles about 1 1/2 years ago and completely stopped charging about 3 months ago.
Good news is they are standard AA rechargable batteries, so you can do what I do and simply swap the batteries with another device like phone or camera and charge them in the other device or buy a small wall charger and use it for rechaging once the unit completely stops.
As for the other comment, MX Revo and similar MX series do not have a "user serviceable" battery and as such there is no easy access to it, first try the above suggestion to clean contacts then, if it doesn't work and you have the skill to disassemble and saulder together new battery cells feel free to pry it open, it's preasure fitted but I would recommend just buying a new one as the cost barely justifies the time and expense of rebuilding it.
Chris
Jun 02, 2009 | Logitech Cordless Mouse
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
Universal Remote Control MX-3000 LCD Touchscreen Remote Control Logo
132 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
