Question about Yamaha HTR-5230 Receiver
Subwoofer how to connect my yamaha sw 201 sub woofer to my htr 5230 receiver
    Novelist:
  • 236 Answers
The best connection is to connect your sub to the output connector (subwoofer) of your HTR. it should have one. But you can also connect parallel to the speakers, any of right or left speakers or both. i normally connect to the speaker set B if thorugh the speaker connections.
Posted on Mar 31, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
I have the same tuner.on the back you will see all connectors bottom row of rca jacks you will see subwoffer if your sub has to rca. red/white use a splitter monstor cable gold ..works best. i use Home Theater Reserch speakers... you can also plug your subs power plug into the tuner snd you never have to power it on seprate .........
Posted on Dec 13, 2007
I just bought a subwoofer and I cannot get it to work. I changed the receiver setting to SW = YES. Where is the correct place to plug it in the receiver, there are two subwoofer outlets.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Aug 04, 2011 | Pioneer VSX-D514 Receiver
How do I properly wire 2 6ohm bose 201v speakers and 1 sub to a yamaha HTR-6130 amp
According to each product's manual.
Bose.com for the 201's.
Register and download the HTR manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-6130-Receivers-manual/id/15220bh542/t/2/
SUB???
May 15, 2011 | Audio Players & Recorders
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
Yamaha htr5230 hookup
Hi, Your receiver is really the same as my HTR 5240. Same back and front. basically. Go to Retrevo for manual. Shows all the hook ups. I have VCR , DVD, Tape Deck, hooked to mine but can't find the adapter so i can hook up my indoor fm antenna. All my components plug to back of receiver then there is one RCA wire running from receiver to Tv.
Sep 01, 2008 | Yamaha HTR-5230 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
Yamaha HTR-5230 Receiver Logo
307 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
