Question about Jenn-Air JSD2789GES Side by Side Refrigerator
Was accidentaly locked and i forgot how to unlock
Ice maker and watr was accidentaly locked and i forgot how to unlock it
  • 415 Answers
Just push and hold the lock button until the lock light goes off sometimes up to 90 secs
Posted on Sep 06, 2009
How to unlock a Scotsman ice machine code L board lock?
Push and hold in the on button for 3 seconds keep holding then press and release the off twice. it will unlock the controller
Aug 26, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How to unlock a scotsman ice machine code L board lock
Turn off machine. turn back on. what other code is it giving something is locking the board out.
Oct 02, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I Have Kenmore side by side model #10657022601. I cant unlock control panel for water and Ice , I hold the button in for 10 sec and stay lock , it should unlock in 3 sec.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment. Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
Aug 07, 2012 | Kenmore Refrigerators
There is water dripping into fridge from just below the freezer, freezer is cold and fridge is cold but watr dripping.
you have a clogged drain hose you need to take out the back cover in the freezer and with a turkey baster and out water you will need to defrost the drin hose
Apr 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore Elite top mount refrigerator getting ice on top shelf and watr accumulating on bottom and in vegetable drawer. I cleaned the freezer and unblocked clogged ice but it still is a problem.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Kenmore 21.7 cu. ft. Top Mount...
How do I unlock the ice-maker panel?
Press the lock again to unlock. If the second padlock is on, press and hold for 3 seconds to unlock the child lock.
Jun 28, 2010 | Bosch Evolution 800 B20CS80SNS Stainless...
Water is not dispensing. Can hear water flowing. Not coming out.
Watre control valves have 2 sides one side for the ice maker and the other for the water didpenser. It is possible that the side for your dispenser is defefective and the complete valve will need replaced. The part number for yours is WR57X10032 and can be found here
http://servicepartstec.blogspot.com/ Just enter the number and click find it. Thanks, Sea Breeze
Aug 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice maker not working went on vacation and turned water off. seems the watr guide into the Ice maker is blocked. Was wondering why this happens, as action should be similar to stopping Ice making with...
When the water is shut off by the lever, it is shut off at bottom of fridge. When you shut it off, it is allthe way to the tray as it gave water permission to travel and what was left filled the line. Unplug fridge for an hour. Should be fine
Aug 09, 2009 | Whirlpool ED5FTGX Side by Side...
Kenmore Elite Fregirator
i have the same fridge, you have to press and hold the Lock button and it will unlock the ice/water for you.
Sep 15, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
341 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
