Question about Motorola Mobility KRZR K1m Cellular Phone
When i close my motorola krazor phone the screen will go black but the light will not shut off an its running my battery down i tried changing everything an nothing seems to work what do i do????
My hp pavilion dv7 keeps running after the lid is closed
Change the settings in the Power section to shut-down when lid is closed. Power Settings, Advanced Settings, Change setting to shut-down when lid is closed.
Oct 29, 2012 | HP Pavillion Dv7-6165us 17.3" Amd...
Motorola c139 phone back drop light will not light up or show menu and the battery works in a differnt phone.
Dear Jodinagy. Be sure that the problem isn't about the battery, but it could be even from the screen or the nap, try to by another screen and change it. But u said that it will not drop light up, so try that, or check your charge circuit, may be the charge don't get in easely or didn't, it happens for me; i've a nokia 3110c, the screen turn to black, and it does'nt change ubtil a change its screen.
Jun 19, 2011 | Motorola Mobility TracFone® V170 Cellular...
Froze on video and now black screen
Try pressing the back and home keys a few times. Sometimes a program hangs and the input prompts android to display the force close option to end the application.
If that doesn't work, try holding in the power button for about 10 seconds and see if the power down options appear (this might cause the force close to appear too, if so go for that method, if not shut down and power back up).
If none of that helps, you may need to pull your battery and boot it back up.
Please leave feedback if you found this helpful. Thanks.
Mar 31, 2011 | Motorola Mobility MILESTONE XT720 Cell...
Last night the screen for my Motorola V365 stopped coming on. I hear the usual musical tones when the phone is turned on or off, and the keys light up for a few seconds as usual, but the screen remains...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 01, 2010 | Motorola Mobility V365 Cellular Phone
Krazor wldnt *** on
Sounds like it might need flashed. You can contact your service provider for that or call Motorola at 1-800-331-6456.
Oct 14, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Password locked phone
sir try deafault password 1234 or 0000
Sep 13, 2009 | Nokia 6233 Cellular Phone
Motorola V3 keep shutting down
Try a new battery if that does not work then you should take the phone and have the firmware flash to correct this error.....take the phone to a mobile service center to have this done.
Oct 25, 2008 | Motorola Mobility RAZR V3
V3i
hi..ur motorola v3i is defaulted with 7 to 10 hrs of battery life only...o save more power...
  • Keep the brightness on the screen to a minimum. You can also adjust how long the backlight stays on without input from the user.
  • Turn off the Bluetooth when not in use. Bluetooth is a big battery draw.
  • Disable incoming beams so that the phone isn't constantly "searching" for infrared partners.
  • Completely close non-essential programs. When you run an application, it does not shut down completely when you "close" it. It is simply minimized. Go into the Settings to completely shut down any programs you are no longer using
  • also u cud get a car charger so that u cud be sure not to run out of juice..
    Thanks for using Fixya
    Aug 22, 2008 | Motorola Mobility RAZR V3i Cellular Phone
    Jabra and Krazor problem
    on jabra try holding vol butten and talk swich hold it till it blue light stars continue and then try surching in ur phone reply me
    May 18, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
    Blank screen
    Take it back, they have to echange it!!! You'll keep the SIM card, so no info will be lost.
    Mar 14, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
    Motorola Mobility KRZR K1m Cellular Phone Logo
    65 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Rami Obeid
    Level 1 Expert
    Richard Lane
    Vernon Taylor
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
