As there is no water entering the machine, check ;-
Water-inlet valve
The
water-inlet valve lets water enter the machine. If this valve is
defective, you need to completely replace it. It's usually located
behind the lower access panel on the left or right side. It's the
device with the main water line (usually copper) from the house, a
rubber tube to the dishwasher, and two wires attached to it.
Float switch
The
float switch is a small electrical switch that's located right below
the dishwasher "floor." Above the switch, on the inside of the
dishwasher, is a plastic cylinder that floats up as water fills the
dishwasher. If this switch is defective, or if the plastic float gets
caught or trapped in the raised position, the water can't enter the
dishwasher. If the float switch is defective, you need to replace it.
no the voltage to the valve should be 120v to operate it check the float inside the tube area and ensure it is in the down position. also make sure it move freely up and down to allow the continued series circuit to complete
Was this helpful?
Yes
No
Popular Solutions for GE 24 in. GSD6660GSS Built-in
My GE Triton dishwasher does not dispense water at the end of the cycle. Every other cycle is...
(More)
My GE Triton dishwasher does not dispense water at the end of the cycle. Every other cycle is complete except the last one. can you provide some solution why the last cycle does not work?
i have a fridgidair dishwasher. when opening the door it squeeks like like a rusty henge. it does...
(More)
i have a fridgidair dishwasher. when opening the door it squeeks like like a rusty henge. it does the same when i close it. i have lubed everything with white grease but it still does it.
