Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Leaking washing machine
I'm having the same trouble with water showing up on the floor close to the front of the washing machine. It doesn't go unbalanced and I have no errors on the machine. It seems to be washing clothes fine also, but for some reason there is water on the floor. I have had this machine for almost 2 years with no trouble and I absolutely love it. I sure hope this isn't a sign of many more problems to come. If anyone found a solution to this problem, I would love to hear it. But in the meantime I will try phoning the company.
  • 415 Answers
Maybe to pump leaking or a hose has come off for the rinse cyc that flushes the fabric softner into the tube if its a smaller amount of water.....try this select a wash cyc let it fill up and wash for a short time then inspect the front of unit for water if no water push cancel/drain and let it drain insp front still no water then I would check for a loose hose or a cut in a hose
Posted on Sep 06, 2009
Washer leaks on floor from drum top while centrifugating
Good Morning Andres,
I see that you are having trouble with your Frigidaire laundry center, model# FEX831F, and the washer leaking water from the drum top onto the floor. It could possibly be that your washer door is either not closed all the way or is not sealing properly. I suggest checking to make sure that the door is closed all the way. If it is, I would check the seal, and see if there anything that might be damaged and allowing water to leak from the drum top. If you are unable to find anything that might be allowing the water to leak out, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and see why you are having water leak from the drum top. Hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire FEX831F Top Load Stacked Washer...
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Washing machine spins but not adding water;
There are a couple of possibilities:
  1. Your shutoff valve may be stuck in the 'closed' position; or.
  2. Your machine may have developed a leak and the automatic cut-off might have engaged to avoid damage to your floor or flooding,
If your inspection turns no leaks or dampness, then have the cut-off valve checked.
Apr 22, 2012 | GE Energy Star WCVH6260F Front Load Washer
Hello ! I have the LG wm2277hs washer machine. the problem that we are having right now is the water leaked after washing. Pleaase show me how to trouble shoot that, thanks
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere back of the drum. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly.
Please post back in case of any issues. Hope this helps...
Daniel
Mar 26, 2011 | LG WM2277H Front Load Washer
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Leak in washing machine
can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Dec 21, 2007 | Washing Machines
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
May 24, 2007 | Hotpoint WF430 Front Load Washer
Leaking....front door won't close
Carefully look at the door gasket to see if any irregularity in seal. Could be problem with door seal; or you could easily change door mechanism thru a spare part shop quoting your model and spare-part No or "door mechanism"
Mar 28, 2007 | Kenmore 43042 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
155 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
