Question about GE WSXH208A Front Load Washer
Dishwasher turns on but no water is going into the dishwasher it is a GE potscubber 970
  • 415 Answers
Check your float assy it the round looking item in the front under the lower rack then make sure it get pushed down then try again if not then replace the water valve its gone bad
Posted on Sep 06, 2009
My GE potscubber water jet is not moveing water . The water is discharging is there help?
most likely ther is a spring returned check ball in the white disk just above the bottom that are known for sticking, but if you open the disk to clean it, you will have to put silicone on the outer edge of the disk and wait a full day before use. if the disk is not sealed well, the washer will not drain all the way.
Aug 26, 2015 | GE Dishwashers
Ge potscrubber 800
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Jun 01, 2013 | GE 24 in. GSD3400G Built-in Dishwasher
Potscubber 1130 making grinding noise?
ck chopper may need to clean internal parts
Feb 04, 2010 | GE Dishwashers
GE Dishwasher that will not advance cycles
sounds like inlet valve is not opening or water has been turned off or kinked.
Sep 14, 2009 | GE Dishwashers
As there is no water entering the machine, check ;-
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water will no enter my dishwasher
check out you're hoses.. the mice might have chewed through them. that happened to my sister
May 30, 2009 | Dishwashers
Skips 1st water fill ?
There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
May 08, 2009 | Maytag Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water not draining completely
I fixed a similar problem by changing the ELECTRIC ANTI-OVERFLOW VALVE located at the back of the machine.
Dec 01, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwasher Does Not Cycle
IA, these GE pumps have a habit of sticking if the unit hasn't been run for a while. First you want to verify that the motor is in fact getting power, this will eliminate the timer. You can use a meter on the quik connect from the motor while in the wash cycle. If the motor is getting power, see if the pump is stuck by turning the motor vanes (Do this with the power off). If it's hard to turn and then frees up than this was more than likley your problem. You remove the bottom toe panel and will be able to check this out without removing the dishwasher. Catriver..post back
Dec 29, 2006 | GE 24 in. GSD2230Z Built-in Dishwasher
GE WSXH208A Front Load Washer Logo
56 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
